PS2 MI 晶片FIRMWARE 1.5 更新
  • 主題發起人 主題發起人 wj2k
這.....要怎麼用? :??:
給樓上的大大,使用方法如下:
BURNING TO CD:
- Create a directory on your desktop or other location of your HD.
- Unzip the ".cue" and ".bin" files present inside the .zip file into this directory.
- Open your preferred burning program (Nero, alcohool120%, etc etc.) and choose
option to burn a "CD-ROM ISO".
- Press the file selection button and choose file type "Image Files (.cue)".
- Navigate to the directory where you unzipped the V1.5 files and select the
"infv15.cue" file.
- Burn the CD.
UPGRADING INFINITY:
- Insert the burned CD into the PS2 and press reset.
The CD should boot authomatically and you will be presented with the Upgrade sreen.
- Follow instructions on screen to upgrade Infinity.
- NOTE : You can always recover from a bad flash by hoding the reset button until
==== the blue eject light turns on. This will let you boot the upgrade disc
to reflash your Infinity.
可以把HDL裝在硬碟裡了..記憶卡又多了些空間來存遊戲囉..
