A thermoelectric module is a solid state device which can operate as a heat pump to transfer heat utilising the "Peltier effect." The three modules are suitable for cooling or heating applications up to 100 degrees C.
Measures: 40 x 40 mm with lead wires.
Temperature Differential (DT) (Th=27 degrees C) : >=68 degrees C
Optimum Input Voltage (Vmax) (Th=27 degrees C): 15V
Optimum Input Current (Imax) (Th=27 degrees C):8A
Maximum Cooling Power (Qmax): 68.09W
