【媒體燒錄】Nero Lite 9.4.13.2d 多國語言版~最新瘦身版
這真是好物
找了一整晚終於找到了
感謝大大
0.0
【軟體名稱】:Nero Lite 9.4.13.2d
【軟體語言】:多國語言(繁簡中)
【軟體分類】:媒體製作、燒錄、複製
【檔案大小】:44.4 MB
【檔案類型】:RAR壓縮檔【WinRAR v3.90 繁體中文正式版 (32bit + 64bit + Protable)】
【解壓密碼】:***回覆後可見***
【驗證 碼】:8dfa0ac9163672eb46171ece6def36a2
【官方網頁】:http://www.nero.com/cht/nero9-introduction.html
【內容介紹】:
Nero Lite installer 包含下列產品:
- Nero BurningROM
- Nero Express
- Nero Cover Designer
- Nero ToolKit (DiscSpeed, DriveSpeed, InfoTool, BurnRights)
- Nero WaveEditor
Nero 9 系統需求:
- Windows Installer 3.1 or higher
- Microsoft Visual C++ 2005 SP1 Redistributable (included into installer)
Note:
Installation size is bigger again, because of problems in Vista and Seven - associated icons were not showing.
Anyway, comparing to installation size of original Nero which is 780MB when same applications are selected, this is small, and today HDD's are cheap.
Uninstaller is included, but it won't be showed in Add/Remove programs.
You will have the shortcut in Start Menu of it and you can use the installer for uninstall.
After uninstall you will probably have to reboot (you'll get prompt if needed) because some files are in use and can be only deleted after reboot.
Do not try to install again Nero if you did not reboot after uninstall, because commands are added which will delete remaining Nero files/folder on next reboot.
如之前有安裝過其他原版舊版本但沒有完全移除乾淨造成安裝上出問題
請下載Nero General CleanTool 清除工具,將您電腦中剩下的 Nero 項目全部刪除
http://www.nero.com/cht/tools-utilities.html#tab4
【下載】
Nero Lite 9.4.13.2d
Nero Lite 9.4.13.2d
Nero Lite 9.4.13.2d
Nero Lite 9.4.13.2d
thx!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
