Help!Gigabyte GA-MA770-UD3 or GA-MA78GM-US2H ?
  • 主題發起人 主題發起人 apvm
666 Thank you so much for your help, I think I'll get the GA_MA790X_UD4P since the AMD3 motherboards you mentioned do not support the 9500. Thanks again.
You're welcome. ^^
666, I finally ordered the GA-MA770-UD3 because not enough 預算 and it is for a 9600 only...I think the 790X will be an overkill, also I don't do crossfire..so I hope I didn't make a mistake...thanks again for your help.
MSI的790板子可以考慮看看
我不知道你在哪個國家......
前一陣子台灣的MSI-790主機板很便宜
MSI KA790GX-M
可以自己找一下拍賣多少錢
GA-MA770-UD3.....
這也不錯
是一塊好板子
蠻超值的(C/P值很高)
666, Thank you,,,I am from Canada...MSI is more expensive than Gigabyte here....
The price difference between MA790X and MA770 is about CAD$50, I think about New Taiwan Dollars $1400...Thank you very much for your help.
I am saving up for DDR3 and AM3 upgrade in 2010, so don't want to spend too much on DDR2 motherboard.
樓主.住在加拿大..可以買的到微星的機板.
但是微星主機板在加拿大賣很貴..
這二塊板...MA790X和MA770價差約50元加幣..合台幣約1400元.
樓主在2010年會升級到AM3跟DDR3的系統..
所以不想在目錢的裝備上花費太多了..
所以他還是千萬個感謝你的回應..
但是微星主機板在加拿大賣很貴..
所以不想在目錢的裝備上花費太多了..
所以他還是千萬個感謝你的回應..
嗯
感謝網兄的翻譯
(雖然我也看得懂啦) XD
台灣的MSI跳水跳很兇的說
想不到在國外是這樣"高貴"的品牌 -_-|||
給樓主
像是MSI 790FX-GD70......
還有MSI 790GX-G65
這些都是DDR3的
可以列入考慮
(雖然MSI在加拿大很貴........XD)
