Template Compilation Error
public:helper_js_global :: head() - array_merge(): Argument #2 must be of type array, string given in /home/coolaler/public_html/forums/src/XF/Template/Templater.php:2244
public:page_style - Unsupported operand types: string + string in /home/coolaler/public_html/forums/internal_data/code_cache/templates/l4/s33/public/page_style.php:101
Template errors
  • Template public:ozzmodz_sc_macros: [E_USER_WARNING] Method canViewScheduledContent is not callable on the given object (XF\Entity\User) (src/XF/Template/Templater.php:1277)
  • Template public:thxpress_thread_insert: [E_USER_WARNING] Accessed unknown getter 'XLinkEntityLink' on XF:Thread[108023] (src/XF/Mvc/Entity/Entity.php:224)
  • Template public:thread_view: [E_USER_WARNING] Method canPromoteToXPressArticle is not callable on the given object (XF\Entity\Thread) (src/XF/Template/Templater.php:1277)
  • Template public:PAGE_CONTAINER: [E_USER_WARNING] Method canViewAnyScheduledContent is not callable on the given object (XF\Entity\User) (src/XF/Template/Templater.php:1277)
  • Template public:PAGE_CONTAINER: [E_USER_WARNING] Accessed unknown getter 'thuix_font_size' on XF:UserOption[0] (src/XF/Mvc/Entity/Entity.php:224)
  • Template public:helper_js_global: [E_USER_WARNING] Function uix_extra_css_urls is unknown (src/XF/Template/Templater.php:1197)
  • Template public:page_style: [E_USER_WARNING] Function uix_intval is unknown (src/XF/Template/Templater.php:1197)
  • Template public:uix_config: [E_USER_WARNING] Function uix_intval is unknown (src/XF/Template/Templater.php:1197)
80G*2 RAID 還是萬轉 36G*1
  • 主題發起人 主題發起人 chiyu
chiyu 說:
不會吧?!組RAID之後不能超頻....
那如果用p4c800ed上另一個SATA晶片組也會有這個問題嗎?!
p4c800ed因該沒問題
我的2號机P4c800-D 3.2G超3.6G
組Raid-0用了半年 ;em03;
有掛過1棵硬碟,但因該不是超頻的事吧....是我家電源不足
時常無故斷電. ;bike; 現加了個ups... ;em25;
萬轉36G沒想像中那麼快...價錢也 ;ng;
用2棵80G組Raid-0吧
個人感覺以前用875板子上組Raid-0 2*120G
比現在用nF4 +萬轉36G*2Raid-0 爽多了..感覺在875板子比較快
我會選36G萬轉*2,~sata2*2=raid雖然看起來測ㄉ數字很好看,但當多工狀態下死的很難看親身體會
最主要是看樓主啦,爽在數字還是真正的感受,雖然scsi價高但是多工強的不得了
我是2種都有..... ;em03;
WD SATA2 80G 8M 7200轉.....*2---->Raid-0(目前使用中) ;face0;
WD SATA1 74G 8M 10000轉...*2---->Raid-0(灌好OS連驅動都還沒裝....當預備OS) ;couch2;
hicookie 說:
;face12; 讓我想想,875超頻之後,不是sata不能作業嗎? ;sorry;
並不會阿
我之前的電腦 P4 3G oc 3.6G
主機板用 ASUS P4C800 Deluxe (875的版子)
三顆硬碟都是接 SATA 也是跑的好好的
跑了一年左右 也沒出過啥問題
另外 板大的選擇 如果是我
我會選 單顆萬轉的吧
現在沒錢買兩顆 等以後有錢在買一顆回來就好
沒必要將就著用
chiyu 說:
想讓系統效能再向上提升~~
所以想問問80G*2 RAID 跟 萬轉36G*1哪個好?!(4000元以下)
3.0cg
p4c800ed
DDR400 1G*2
Seagate 7200.7 200G*1 (IDE)
你要的是怎樣的效能?
據我所知....raid0對系統效能的影響可以說是微乎其微...
只有在傳輸大檔案的時候比較顯的出差異,
AnadTech有一篇比較單顆WD740和WD740 raid0的報導,
建議你可以先去看看
那篇的結論是:
RAID-0 arrays will win you just about any benchmark, but they'll deliver virtually nothing more than that for real world desktop performance. That's just the cold hard truth
