【軟體名稱】:xplorer² Pro 1.8.1.3 - Final~免安裝
【軟體語言】:繁體中文
【軟體分類】:檔案管理
【軟體格式】:RAR
【檔案大小】:1.89 MB
【放置空間】:depositfiles/ mediafire
【解壓密碼】:no
老牌子的檔案總管,相信是許多老玩家的最愛,以抬面上支援雙視窗的檔案總管,xplorer2無疑是效能最佳的一款。它具有跟Windows系統內建的檔案總管相當類似的介面,這也就是意味著他的操作更具親和力,完全可以替代系統的檔案總管,而它獨有的許多項超方便功能更是讓人愛不釋手。
[1.8.1.3] 6 Mar 11 ----------------
* [P] Help > Activate with key menu command easy way to use your unlock key to activate xplorer? This menu is disabled if you are already registered.
* Folder deletion from the tree got easier, now you don't have to activate the confusing 'Don't lock browsed folder' advanced option.
* Hide protected operating system files policy from Folder Options (Control panel) is observed, unless you use the registry tweak GIOPT_SHOWALLHIDDEN(=256) ?then xplorer?will behave like it always had. (it only makes a difference for windows 7 and later)
* various small bugfixes (e.g. symbolic links)
