WinSysClean X 10.00 Build 450
  • 主題發起人 主題發起人 viet80
viet80
Info:
RWinSysClean is the most effective registry cleaner, there is no other registry cleaning tool which is easier to use or more effective than WinSysClean with just a single mouse click.
By running WinSysClean, you will get more disk space and Windows will run faster after a clean operation. The error files that WinSysClean searches for and deletes can produce very hazardous results if not properly cleaned from your drive on a periodical basis. All this tasks are done by Professionals periodically by hand, now you can do it with just a single button click without being affair of damaging something !
• WinSysClean remove specific types of files that common disk utilities, uninstall, setup, defrag, scandisk, and other cleaner type programs will miss.
• Cleans your computer's registry by deleting invalid uninstall entries and other wasted registry entries, leaved by programs after uninstalling them.
• WinSysClean uses advanced registry analysis in order to detect invalid entries, so you don't need to make critical decisions to confirm which entries to be removed, because WinSysClean does this for you safely.
• You can choose from many cleaning options, or you can let WinSysClean do it for you with the default settings.
• Internet Explorer Favorites Update / Repair. This feature will help you to maintain the Internet Explorer favorites, WinSysClean will keep them up to date and will help you to remove or repair invalid favorites. WinSysClean also download icons if they are available from each website of your favorites and associate them with the favorites.
• Cleans the Windows Recycle Bin.
• Removes the Windows Documents History.
• Deletes the Windows Hotfix uninstall files.
• Deletes the Windows RUN History.
• Deletes the Internet Explorer typed URL History.ns the Internet Explorer Cache Folder.
• Cleans the Internet Explorer Cookies Folder.
• This version includes over 30 integrated cleaning modules.
• Deletes the Windows Registry Backup files (these backup files are created at every Windows Startup, and it is wasting very much disk space).
• Ability to add custom file types and custom folders.
• Removes the invalid Registry Application Paths.
• Removes the invalid font entries from Registry.
• Registry Backup and Restore option.
• View a complete log of the operations executed by WinSysClean, after the cleaning process.
Changes in WinSysClean:
- NEW! Uninstall option for Installed Programs with Search, Rename and Delete entries which cannot be uninstalled from Control Panel - Add/Remove Programs.
- NEW! Skype PM Message Archive, Voice Mails, Call logs and My Received Files cleaning. * World's first cleaner to support Skype!
- NEW! Explorer History / RecentDocs cleaning.
- NEW! Google Earth Cache cleaning.
- NEW! Apple Installer Cache cleaning.
- NEW! iTunes Album Artwork Cache cleaning.
- NEW! iTunes iPhone & iPod CrashReports Log files cleaning.
- NEW! ATI Display Driver Installer temporary files cleaning.
- NEW! Windows Error Reporting temporary files cleaning.
- NEW! Added button in main window to view the last cleaning log.
- Improved: User Interface functionality and speed.
- Improved: Empty folders cleaning.
- Improved: Memory usage to avoid GDI leaks and heap errors.
- Updated: Help file.
- Fixed: DCOM timeout problem on some slower systems.
- Other minor fixes and improvements.
代碼:
Download Link: (Rapidshare)
http://rapidshare-is.blogspot.com/2010/02/part1_7451.html
No Pass
