Board is well-design and built for sure besides the 4 pins molex located at the last PCI slot.:ocx48: , also the bios is so easy to corrupt. The first one let me install everything fresh and without any difficulty, but after couple hours, power off and power on, the on board debug led just show "8E" then automatically shut down.
After RMA to Newegg and receive today, samething happened ; even I just adjust some parameters of uGuru options, then directly went down exactly same as the first board.
Let's see the parts of this board:
This figure is from Ancient China era, means fortune and luck.
Very well pack it!!:ocx22:
Accessories
Wifi
THe Board
the heat pipe...welll:ocx48:
all the high end electrical board elements placed.
Cpu socket area is pretty good for going extremely cold insulation job.:)
wow, this chip is vista certified no problem
the I/O area
here is the big big mistake, if user need to use the extra power when apply SLI operation, what should they do?
nice, big NB heatsink but did not block
Test set up:)
the area after install memory and ultra 120 heatsink with 120mmx38mm
power up ..:D
We will go on for Bios page!:MMM:
Accessories
Wifi
THe Board
the I/O area
Test set up:)
power up ..:D
