我的電腦偶爾會有突然跳成藍色畫面
但是藍色畫面只是瞬間 就重新開機了
無法把錯誤訊息抄下來~
剛剛使用SP2004 測試出現了下列錯誤訊息
Type: Large, in-place FFTs - stress some RAM Min: 128 Max: 1024 InPlace: Yes Mem: 8 Time: 15
CPU: 1809MHz FSB: 201MHz [201MHz x 9.0 est.]
2006/7/27 上午 11:39 Beginning a continuous self-test to check your computer.
Press Stop to end this test.
Test 1, 4000 Lucas-Lehmer iterations of M19922945 using 1024K FFT length.
Test 2, 4000 Lucas-Lehmer iterations of M19922943 using 1024K FFT length.
Test 3, 4000 Lucas-Lehmer iterations of M19374367 using 1024K FFT length.
Test 4, 4000 Lucas-Lehmer iterations of M19174369 using 1024K FFT length.
FATAL ERROR: Rounding was 0.5, expected less than 0.4
Hardware failure detected, consult stress.txt file.
Torture Test ran 13 minutes 19 seconds - 1 errors, 0 warnings.
Execution halted.
請問這是代表我的電腦怎麼了? 還是??
拜託大大們幫我解疑惑^^
但是藍色畫面只是瞬間 就重新開機了
無法把錯誤訊息抄下來~
Execution halted.
請問這是代表我的電腦怎麼了? 還是??
拜託大大們幫我解疑惑^^
