今天放者養動物 又跑去睡 開了大概3.4小時起來看 藍天白雲
出現 nltdi.sys的藍色畫面 也就是說有時候是重開機有時候藍天白雲
A problem has been detected and Windows has been shut down to prevent damage to your computer.
If this is the first time you've seen this stop error screen,restart your computer.If this screen appears again,follow these steps:
Check to be sure you have adequate disk space.If a driver is identified in the stop message disable the driver or check with the manufaturer for driver updates. Try changing video adapters.
Check with your hardware vendor for any BIOS updates Disable BIOS meomry options such as caching or shadowing.Ifyou need to use safe mode to remove or disable components,restart your computer,pressF8 to select advanced startup options,and then select safe mode.
STOP:0x0000007E(0xc0000005,0xF456B168,0xF7D05BFO,0xF7d658EC)
nltdi.sys-address F456B168 base at F4562000 Datestamp 43a5e989
