[求教]有人用Matrox Marvel G400-TV嗎?
  • 主題發起人 主題發起人 buniro
buniro
我從英國買了一張Matrox Marvel G400-TV,但它是PAL的,
請問要如何將它切換成我國的NTSC系統呢?
:rolleyes:
我沒記錯的話,卡上面有一個jump可以調pal和ntsc,找看看吧!
找不到耶!等下我把圖po上來,請您指點。 :P
圖來了:
上面好像沒有Jumper可以調說!
是從顯示卡BIOS下手嗎?
注意看:
http://www.matrox.com/mga/archive_story/ap...arvg400_cnn.cfm
�面就有寫:
Supports globe-trotting
The Marvel supports both the NTSC television signal system used in most of North America, and the PAL system used in Europe and many other parts of the world.
這是否代表每一塊卡都能任意切換PAL或NTSC來TV-out呢?
另,Matrox的Unified BIOS檔ReadMe.TXT提到:
TV output is supported with Windows 98/Me/2000, Windows NT 4.0,
and DOS. By default TV output is disabled. If TV output is
disabled, a TV connected to your computer will display black. For
information on how to enable TV output mode in Windows 98/Me/2000
or NT 4.0, see Matrox online documentation.
有大大知道哪裡可以找到上面所說的online documentation嗎?
我找了一下, 因為我記得之前有看過相關文件, 以下的文字是接著你上面的敘述的!
To enable TV output for DOS display modes, the BIOS of your Matrox
graphics card needs to be configured.
DOS display modes may be used when:
- your computer is restarted in DOS mode
- DOS programs are run full-screen
- a full-screen DOS prompt is used under Windows
- text is displayed on your computer monitor before Windows starts
Note: For G450-based graphics cards, DOS display modes are not
supported.
BIOS configuration
To configure the BIOS of your Matrox graphics card to support TV
output for DOS display modes:
Windows 95/98/Me/2000 or NT 4.0
(1) Click "Start" -> "Run", type "c:matroxutilpbioswin", then
click "Update the Matrox Graphics BIOS".
If you have more than one graphics card, select the graphics
card you want to update.
Note: DOS display modes are only supported on the primary
display.
(2) Select a TV standard (*), then click "OK".
(3) After the BIOS is updated, make sure no disk is in your disk
drive, then restart your computer.
DOS
(1) Make an emergency disk (see "Matrox emergency disk").
(2) Type "cd c:matroxutil", then press [Enter].
(3) Depending on the TV standard (*) of your TV output device,
type "progbios -maven ntsc" or "progbios -maven pal". (To
disable TV output support for DOS display modes, type
"progbios -maven off".)
(4) After the BIOS is updated, make sure no disk is in your disk
After restarting, when a DOS display mode is used, your Matrox
graphics card will automatically work with a TV or VCR connected
to it.
* NOTE: Two TV standards are supported for TV output. NTSC is used in
North America and Japan, among other places. PAL is used in most of
Western Europe and in China, among other places. If you're not sure
what standard your TV or VCR uses, see its documentation.
在BIOS 檔案的說明檔就有了~~~
先去下載BIOS, 在按照步驟做就好了~~
supported.
BIOS configuration
display.
DOS
to it.
在BIOS 檔案的說明檔就有了~~~
感謝Mondeo兄的第一次就獻給了本篇!
我有看到這一段,但是看起來好像是「DOS下的TV-out設定」,
這似乎是在DOS下要TV-out才用此法設定的,那不知道在Windows下
要TV-out的話,也是用相同方法設定PAL或NTSC嗎?
還是Windows下如要TV-out,不須更新BIOS設定,直接
在Windows下,顯示器的內容中就能調整了呢?
懇請大家指教!
我是想說...透過這個DOS 設定程式搞不好就可以搞定了...
您要不要試試看?
因為我只有G400..... :QQQ:
有遇到問題的話...歡迎在上來討論囉~~ :MMM:
