各位大大好,小弟有一顆E8400 E0(Q826A397),
原在P5K Premium上能以533x8(1.244v)跑ORTHOS 30分鐘過測,
但是自從換了P5Q-E之後,同樣的U跟設定,就是過不了,
總是在7分5X秒的時候,第二顆核心就爆了,
之前有試過將倍頻降到7,卻可以順利的跑過,
不知道是主機板還是設定上的問題,
以下是小弟的BIOS設定,請各位大大幫忙指導一下,謝謝!
測試平台:
CPU:E8400 E0(Q826A397)
MB:ASUS P5Q-E(A2版1406)(北橋散熱膏已重上)
RAM:創見aXe 1066 1GBx2(ELPIDA顆粒)
HD:Seagate 梭魚11代 500GX2(RAID 0)
AI Overclock tuner: Manual
CPU Ratio Setting: 8
FSB Strap to North Bridge: AUTO
FSB Frequency: 533
PCI-E Frequency: 100
DRAM Frequency: 1066
DRAM CLK Skew on Channel A1: AUTO
DRAM CLK Skew on Channel A2: AUTO
DRAM CLK Skew on Channel B1: AUTO
DRAM CLK Skew on Channel B2: AUTO
DRAM Timing Control: Manual
1st Information :
CAS# Latency: 5
DRAM RAS# to CAS# Delay: 5
DRAM RAS# Precharge: 5
DRAM RAS# Activate to Precharge: 15
RAS# to RAS# Delay : AUTO
Row Refresh Cycle Time: AUTO
Write Recovery Time: AUTO
Read to Precharge Time: AUTO
DRAM Static Read Control: AUTO(試過Disabled)
DRAM Read Training: AUTO(試過Disabled)
MEM. OC Charger: Enabled(試過Disabled)
AI Clock Twister: AUTO
AI Transaction Booster: AUTO
CPU Voltage 1.275v(試過加到1.365一樣爆)
CPU GTL Voltage Reference (0/2) AUTO
CPU GTL Voltage Reference (1/3) AUTO
CPU PLL Voltage : 1.52(試過AUTO、1.50、1.54)
FSB Termination Voltage : 1.20(試過加到1.30)
DRAM Voltage : 1.9v
NB Voltage : 1.26v(試過加到1.40v)
NB GTL Reference : AUTO
SB Voltage : AUTO
PCIE Voltage : AUTO
____________________________________
Load-Line Calibration [Enabled]
CPU Spread Spectrum [Disabled]
PCIE Spread Spectrum [Disabled]
CPU Clock Skew [Auto]
NB Clock Skew [Auto]
CPU Margin Enhancement [Optimized Mode]
Advance CPU Settings:
C1E Support: [Disabled]
Max CPUID Value Limit: [Disabled]
Intel Virtualization Tech: [Disabled]
CPU TM Function: [Disabled]
Execute Disable Bit: [Disabled]
不知道是主機板還是設定上的問題,
測試平台:
FSB Frequency: 533
1st Information :
CAS# Latency: 5
DRAM Voltage : 1.9v
SB Voltage : AUTO
PCIE Voltage : AUTO
