Nvidia Forceware 91.36 WHQL ( 32-bit / 64-bit ) Final
coolrichard
A new WHQL Forceware graphics drivers v91.36 (dated August 14, 2006 - download - Win2k/XP ~ 21.6MB) are available for download from the official NVIDIA download page. They are compatible with most current GeForce and Quadro graphics cards from NVIDIA!
- WHQL Certified
- Improved performance on workstation applications
- New NVIDIA PureVideo features and enhancements.
- Adds noise reduction post processing
- Adds image sharpening post processing
- Improved Inverse telecine algorithm
- Improved de-interlacing algorithm
- Improved compatibility with third party MPEG-2 decoders
- MicrosoftR DirectX 9.0c and OpenGL 2.0 support
(32-bit) http://www.nvidia.com/object/winxp_2k_91.36
(64-bit) http://www.nvidia.com/object/winxp64_91.36
多謝提供,收下了!~
感謝...嚐鮮去!!!
Product Support List:
Quadro2 MXR, Quadro DCC, Quadro4 200 NVS, Quadro4 400 NVS, Quadro4 380 XGL, Quadro4 500 XGL, Quadro4 550 XGL, Quadro4 580 XGL, Quadro4 700 XGL, Quadro4 750 XGL, Quadro4 780 XGL, Quadro4 900 XGL, Quadro4 980 XGL, Quadro FX 330, Quadro FX 350, Quadro FX 500, Quadro FX 540, Quadro FX 550, Quadro FX 560, Quadro FX 600, Quadro FX 700, Quadro FX 1000, Quadro FX 1100, Quadro FX 1300, Quadro FX 1400, Quadro FX 1500, Quadro FX 2000, Quadro FX 3000, Quadro FX 3000G, Quadro FX 3400, Quadro FX 3450, Quadro FX 3500, Quadro FX 4000, Quadro FX 4000 SDI, Quadro FX 4400, Quadro FX 4400G, Quadro FX 4500, Quadro FX 4500 SDI, Quadro FX 4500 X2, Quadro FX 5500, Quadro FX 5500 SDI, Quadro NVS, Quadro NVS with AGP8X, Quadro NVS 50 PCI, Quadro NVS 200, Quadro NVS 210s, Quadro NVS 280, Quadro NVS 280 SD, Quadro NVS 400, Quadro NVS 440, Quadro NVS 280 PCI, Quadro NVS 285
我好像用不著... ;oq;
這個是繪圖卡用的驅動
這是給 Quadro 專用的耶
繪圖卡的...
91.45是給7950*2用的 除非硬上 就可以用
不然其他都用91.31吧QQ
7600GS 256MB 正確辨識,快樂使用中.......
(用了這版馬賽克解除了,心胸也變的寬大了..............)
Products Supported
Product Support List Windows XP 32-bit – 91.36
Quadro2 MXR
Quadro DCC
Quadro4 200 NVS
Quadro4 400 NVS
Quadro4 380 XGL
Quadro4 500 XGL
Quadro4 550 XGL
Quadro4 580 XGL
Quadro4 700 XGL
Quadro4 750 XGL
Quadro4 780 XGL
Quadro4 900 XGL
Quadro4 980 XGL
Quadro FX 330
Quadro FX 350
Quadro FX 500
Quadro FX 540
Quadro FX 550
Quadro FX 560
Quadro FX 600
Quadro FX 700
Quadro FX 1000
Quadro FX 1100
Quadro FX 1300
Quadro FX 1400
Quadro FX 1500
Quadro FX 2000
Quadro FX 3000
Quadro FX 3000G
Quadro FX 3400
Quadro FX 3450
Quadro FX 3500
Quadro FX 4000
Quadro FX 4000 SDI
Quadro FX 4400
Quadro FX 4400G
Quadro FX 4500
Quadro FX 4500 SDI
Quadro FX 4500 X2
Quadro FX 5500
Quadro FX 5500 SDI
Quadro NVS
Quadro NVS 50 PCI
Quadro NVS 200
Quadro NVS 210s
Quadro NVS 280
Quadro NVS 280 SD
Quadro NVS 400
Quadro NVS 440
Quadro NVS 280 PCI
Quadro NVS 285
The following products are not supported in the current ForceWare Release 90 driver. Please continue to use the previous ForceWare Release 70 drivers available here.
Vanta
Vanta LT
Quadro
Quadro2 Pro
Quadro2 EX
轉載自 http://www.nvidia.com/object/91.36_winxp_32_supported.html
這個驅動 所支援的硬體
