1.品名 :MAYA EX5 USB外接音效卡
2.數量 : 1
3.品相及保固 : 新MAYA EX5 今年購入2007年6月23日,保固中
4.售價 : 2300元
5.地點 : 板橋可面交
6.交易方式:可面交
頻響資料:
Interface: FULL SPEED USB (USB 1.1 COMPATIBLE)
Analog Inputs
Type: 2 Channel Analog line inputs (3.5mm Jack)
Level: -10dBV Unbalanced, -10dBV Nominal, +6dBV Maximum
Impedance: 10K Ohm
Analog Outputs
Type: 6 Channel Analog line outputs(3.5mm Jack)
Level: -10dBV Unbalanced, -10dBV Nominal, +0dBV Maximum
Impedance: 100 Ohm
MIC Preamplifier
Gain: +40dB Fix
Impedance: 10K ohm
Headphone Output
Type: 3.5mm Mini Phone Jack
Output Power: 60mW Max
Signal to Noise Ratio: 110dB (Typical)
(THD+N)/S: -70dB, 0.03% (Typical)
Headset Connector (3.5 mm Jack)
Sample rate supports: 48 kHz
Bits Resolution: 16-bit
Digital I/O
Type: Coaxial input & Output Connector
Type: Mini Optical Output Connector (TOS- LINk)
Format: IEC-958 Consumer (S/PDIF)
Sampling Rate: 48 kHz
Bit Resolution: 16 bit
A/D Converter
Dynamic Range(S/N): 91 dB A-Weighted (Typical)
Frequency Response: 20 ~ 20KHz
Resolution: 18 Bit
D/A Converter
Dynamic Range (S/N): 88 dB A-Weighted (Typical)
Frequency Response: 20 ~ 20KHz (@ fs=48kHz)
Resolution: 18 Bit
開封測試專用,物品幾乎全新!!
為了避免先後順序的問題
請先於版面上下單後在pm給我
謝謝!!
2.數量 : 1
4.售價 : 2300元
5.地點 : 板橋可面交
6.交易方式:可面交
頻響資料:
Analog Inputs
Impedance: 10K Ohm
Analog Outputs
Impedance: 100 Ohm
MIC Preamplifier
Gain: +40dB Fix
Impedance: 10K ohm
Headphone Output
Digital I/O
A/D Converter
Resolution: 18 Bit
D/A Converter
Resolution: 18 Bit
開封測試專用,物品幾乎全新!!
為了避免先後順序的問題
請先於版面上下單後在pm給我
謝謝!!
