【軟體名稱】:MagicISO Maker 5.5 Build 281
【軟體語言】:多國語言
【軟體分類】:燒錄程式
【軟體格式】:RAR
【檔案大小】:3.24 MB
【放置空間】:RapidShare/ depositfiles
【解壓密碼】:no
【軟體介紹】:
MagicISO是一個功能強大的 CD/DVD映像檔編輯、CD燒錄以及CD/DVD備份工具。它可以直接建立、編輯、輸出以及燒錄ISO檔案,也可以將大部分的CD/DVD格式轉換成ISO、BIN/CUE、nero (NRG)以及CloneCD (CCD/IMG/SUB)檔案。透過MagicISO你可以處理達10GB的DVD映像檔;從CD/DVD-ROM製作映像檔;將ISO檔案及其它映像檔燒錄成光碟;支援製作可開機的CD/DVD映像檔;透過ISO9660、Joliet、Rock Ridge以及UDF volume處理CD/DV映像檔;編輯CD/DVD映像檔的特性;支援用取代字元搜索的檔案或目錄;支援透過可開機設定精靈製作多重開機的CD/DVD映像檔;支援輸出可開機設定來建立Linux/Unix 開機光碟。
Features:
- Process almost all CD-ROM image file(s) including ISO and BIN.
- Ability to directly add/delete/rename/extract file(s) within image files.
- Convert image files to the standard ISO format.
- Supports ISO 9660 Level1/2/3 and Joliet extension
- Duplicate disc to ISO file from CD-ROM.
- MagicISO embed with Windows Explorer.
- You can convert almost all image file formats, including BIN, and save it as a standard ISO format file.
- Edit ISO file in many format(such as Nero burning ROM, Easy CD Creator, CDRWin, CloneCD, BlindWrite, etc).
- Select some files or directories, and then create the ISO based on these files.
- Make bootable ISO file.
- Because of its file associations, you can simply double click an ISO file in Windows Explorer to open it.
- Very easy to use interface but powerful enough for an expert.
- Backup CD to your hard disk.
MagicISO Maker 5.5 Build 281_免安裝
確保下載的軟體能正常使用,請使用
