【檔案名稱】:DVDFab Platinum v6.0.4.0 - Final 便攜式
【檔案大小】:36.1 MB
【檔案格式】:EXE
【語言種類】:多國語言
【檔案簡介】:
DVDFab 是一款輕鬆製作完美 DVD 備份的工具。可以實現 DVD 到 DVD 的複製,在複製的同時去掉所有的保護機制,可保留原有的選單、片花和其他功能,可複製到一碟或多碟等。
◆-可以幫助您輕鬆製作完美品質的 DVD 影碟備份的光碟複製工具!
◆-無損複製DVD電影、可複製 NTSC 或 PAL 制式 DVD
◆-可只複製電影部分,去除不需要的音頻和字幕
◆-可燒錄到 DVD-R/RW 和 DVD+R/RW
◆-移除所有的 DVD 保護方式
◆-備份多個光碟
◆-恢復損壞的碟片中的數據
◆-重寫和核心引擎,幾乎支援所有的 DVD!
Changes in DVDFab 6.0.4.0 (July 28, 2009):
* New: Added popup menu for navigation bar so that more options can be used.
* New: Added auto-run handler for Windows Vista/7 64-bit.
* New: Updated language files.
* Fix: Preview cannot be played when play button be clicked in certain cases.
* Fix: HD Decrypter cannot output ISO file when ImgBurn or Nero is configured.
DVDFab "DVD to DVD":
* New: Rewrite "Clone" mode to support "Copy Original IFO Files" better.
* New: Improved PathPlayer.
* Fix: A crash problem when opening "The Edge of Love" (US) if PathPlayer is enabled.
* Fix: Several crash problems when opening DVD in certain cases.
* Fix: A PathPlayer problem that playable content (menu) be removed in certain cases.
DVDFab "Blu-ray to Blu-ray":
* New: Added support for AACS MKB14. Note: user are encouraged to try the new version, even if new disc fails with this version, we can add support for it in one day.
* New: Added support to remove RC, BD-Live and UOPs copy protections for "Clone" mode.
* New: Improved speed when opening Blu-ray disc.
* Fix: A crash problem when opening Blu-ray disc in certain cases.
* Fix: A crash problem when burning Blu-ray in "Full Disc" mode.
DVDFab "DVD to Mobile":
* New: Added "Apple TV, VOB, AVI, MP4, WMV, MKV, FLV, 3GP" output types in navigation bar.
* Fix: Conversion settings cannot be saved in certain cases.
DVDFab "File to Mobile":
* New: Added "Apple TV, AVI, MP4, WMV, MKV, FLV, 3GP" output types in navigation bar.
載點:
解壓密碼:Danfong@Hsieh
【檔案大小】:36.1 MB
【檔案格式】:EXE
【語言種類】:多國語言
【檔案簡介】:
◆-移除所有的 DVD 保護方式
◆-備份多個光碟
◆-恢復損壞的碟片中的數據
載點:
解壓密碼:Danfong@Hsieh
