CoreTemp v0.99.5 Beta2
sxs112.tw
Version 0.99.5.20 - 12th March, 2009
- Fix: Incorrect clock speeds reported on some systems.
- Fix: At startup Core Temp shows 0 (?) or 21 (?) on AMD K8 series.
- Fix: Turion MK series recognition was wrong.
- Fix: Properly detect Atom and Core i7 engineering samples.
- Fix: Tri-Core AMD CPUs incorrectly shown as having only 2 cores and 2 threads in 64bit Core Temp binary.
- Fix: System tray text was off center.
- Fix: Penryn (mobile Core 2) processors reported as having 85C TjMax instead of 90C.
- Add: Completely new code for processor speed detection.
- Add: Running several instances of Core Temp is now possible (enable in Settings).
- Add: A comprehensive processor information windows (F3 or Tools --> System information).
- Change: Temp turns Orange when temperature is over TControl, and Red when CPU is thottling/critical.
新的試用版本,
謝謝大大提供訊息及載點…
下載試用ok!!
感謝大大分享!!但是核心溫度有點高的樣子!!
感謝分享唷!
新的版本,多謝提供 ! ;em28;
謝謝分享~
