;tongue;Name:CloneDVD.2009.4.5.0.0.MULTiLANGUAGE.Incl.Keygen-Chinese Traditional
;tongue;Size:134.5MB/1File
;tongue;Format:.RAR
;tongue;Language:MULTiLANGUAGE (Incl.Chinese Traditional)
;tongue;Service:FREAKSHARE /LoadFiles.iN / ORON
;tongue;Download Tool:CryptLoad / JDownloader / iE
;tongue;Unzip:WinRAR v3.91
;tongue;Category:
;tongue;Limit Save:Never
;tongue;URL:http://www.symantec.com/zh/tw/norton/norton-utilities
Get.Premium.Account High Speed Download
/45 Sec (Member (Asia Zone 150KB/s up Speed Download)
/ 90 Sec (Not Member)
/ 0 Sec Direct Downlaod (Member : Premium Account High Speed Download)
http://imagetwist.com/mz3pzvhx8ulj/download.click.png.htmlDownlaod Tech!!!(Click it)
http://imagetwist.com/wcu9wm1q7sfq/download.click2.png.html
Downlaod1 (5 SERVER)
Download 2 (2 SERVER)
8:00 7:00(AM) Reset Download Traffic
Downlaod 3
PS:use CryptLoad or JDownloader download all part
CryptLoad
JDownloader
JDownloader
CryptLoad
Norton Utilities is an application suite that will provide you with the essential tools you need to optimize the performance of your Personal Computer. It finds and fixes broken registry links and damaged files, frees up disk space, reclaims system memory, accelerates startup time, and boosts application and system performance. It opens applications faster, and lets you run more of them simultaneously. Norton Utilities can help make your PC will run like new again. Unlike other PC tune-up software, Norton Utilities focuses 100 percent on performance and provides easy-to-use tools that make a real difference. Make your computer boot faster by prioritizing the startup programs with Startup Manager. Instead of letting Micros0ft Windows load programs you don?t need, Startup Manager loads only the programs you choose.
Management tools let you view and manage the memory usage of running applications so you can make adjustments that improve PC performance. You can also evaluate the performance of your PC by benchmarking it against other PCs.
Key Technologies:
? Disk Cleaner
? Disk Bleacher
? Startup Manager
? Registry Defragmenter
? Registry Cleaner
? Service Manager
? Disk Cleaner
? Disk Bleacher
? Startup Manager
? Registry Cleaner
? Service Manager
? System Optimizer
? Performance Test?
Key Benefits:
? Finds and fixes PC problems with one click?Automatically detects and fixes Micros0ft? Windows? issues so you can spend more time using your PC and less time troubleshooting.
? Speeds up PC boot time ?Accelerates PC boot time and reduces unnecessary waiting by prioritizing startup applications.
? Reclaims PC memory?Optimizes the registry for quicker application launch and a faster running PC.
? Frees up hard disk space?Boosts overall PC performance by defragging your hard drive, freeing up storage space, and recouping system resources.
? Protects your personal information?Permanently deletes unwanted sensitive files from your PC so hackers can?t access your data.
? Helps prevent system errors?Undoes erroneous registry tasks and commands to help keep your PC running error-free.
? Benchmarks your PC?s performance?Determines whether your PC is performing at its best by benchmarking it against similar systems.
Features:
Solves PC Problems
? Automatically detects and fixes Micros0ft? Windows? issues to keep your PC running fast and error-free.
? Registry Undo eliminates erroneous registry tasks and commands to avoid system errors.
? Puts you in charge by allowing you access to your Micros0ft Windows settings.
Boosts PC Performance
? Startup Manager and Service Manager speed up PC boot time by prioritizing startup programs and Micros0ft? Windows? services.
? Registry Defragmenter defragments and repairs the registry to help applications launch faster and improve overall PC performance.
? Registry Cleaner reclaims PC memory so you can run more applications simultaneously.
? Disk Cleaner optimizes the hard disk to free up disk space and recoup system resources.
? Performance Test shows you how well your PC is performing by benchmarking it against similar systems.*
Increases Privacy and Security
? Disk Bleacher permanently deletes unwanted sensitive files so hackers can?t get at them.
Why Choose Norton Utilities
? Speeds up PC boot time by prioritizing startup applications.
? Fixes common PC problems automatically ? one-click is all it takes.
? Maximizes overall system performance to help make your old PC run like new again.
? Optimizes the registry so programs open faster.
? Defragments and cleans your hard drive to free up disk space.
? Recoups system resources for a fast running PC.
? Optimizes PC memory so you can run more applications simultaneously.
? Purges unwanted sensitive data to increase privacy and security.
? Undoes erroneous registry commands to avoid system errors.
Designed For Windows 7/XP/Vista.
