ARECA 的效能...真是沒話說...
Cache 可以裝到 2g ddr2 的 ram -_-
不知道一片上市要賣多少錢 ;nq; ;nq; ;nq;
而且有像 iRam 功能!?
在cache中最大 read 1624MB/sec
原場連結
http://www.areca.com.tw/products/html/pcietosata1280.htm
Adapter Architecture
Intel 800MHz 81341 I/O processor
PCI-Express X8 bus
One DIMM socket with default 256MB of DDR2-533 SDRAM with ECC protection, Upgrade to 2GB. An ECC or non-ECC SDRAM module using X8 or X16 devices
Write-through or write-back cache support
Support up to 12/16/24 SATA II drives
Multi-adapter support for large storage requirements
BIOS boot support for greater fault tolerance
BIOS PnP(plug and play)and BBS(BIOS boot specification)Support
Intel RAID 6 inside to support extreme performance RAID 6
NVRAM for RAID configuration & transaction log
Redundant flash image for adapter availability
Battery Backup Module(BBM) ready (Option)
RAID Features
RAID level 0,1, 1E, 3, 5, 6 or JBOD
Multiple RAID selection
Array roaming
Online RAID level/stripe size migration
Online capacity expansion and RAID level migration simultaneously
Online Volume set growth
Instant availability and background initialization
Automatic insertion/removal detection and rebuild
Greater than 2TB per volume set
Support S.M.A.R.T, NCQ and OOB Staggered Spin-up capable drives
Support spin down drives when not in use to extend service life (MAID)
Support NTP protocol to synchronize RAID controller clock over on-board Ethernet port
Monitors/Indicators
System status indication through HDD activity/fault connector, LCD Connector and alarm buzzer
SMTP support email notification
SNMP support for remote notification
I2C& SGPIO Enclosure management ready
RAID Management
Field-upgradeable firmware in flash ROM
In-Band Manager
Hot key boot-up McBIOS RAID manager via BIOS
API library for customer to write its monitor utility
Support Command Line Interface (CLI)
Browser-based management utility via ArcHttp Proxy Server
Single Admin Portal (SAP) monitor utility
Out-of-Band Manager
Firmware-embedded Browser-based RAID manager, SMTP manager, SNMP agent and Telnet function via on-controller Ethernet port
Push Button and LCD display panel
Software Drivers
Windows 2000/XP (Scsiport Driver)
Windows Server 2003 (Scsiport Driver and Storport Driver)
Linux (RedHat, SuSE, Debian, Mandrake,TurboLinux, CentOS, etc.)
FreeBSD
Novell Netware 6.5
Solaris 10 x86/x86_64
SCO UnixWare 7.x.x
Mac OS X (no_bootable)
而且有像 iRam 功能!?
原場連結
PCI-Express X8 bus
RAID Features
Array roaming
Monitors/Indicators
RAID Management
In-Band Manager
Out-of-Band Manager
Software Drivers
FreeBSD
Novell Netware 6.5
SCO UnixWare 7.x.x
