http://www.arcticsilver.com/ceramique.htm
這款有2.5G的小枝裝賣
我只用一次的話好像比較不會浪費
我是重裝CPU散熱器用的
重裝後大既很長時間(幾年)也不會再理會他的了
這個有那麼耐用嗎?
因為好像有些會有油水分離的現象,
用一段時間後要換似的
還有,這個的有個特別說明,我不太明白
是指可以裝了塗了很立即用電腦
但要用了25小時後會較好,還是要25小時待著機不用?
原文
Important Reminder:
Due to the unique shapes and sizes of the particles in Céramique, it will take a minimum of 25 hours and several thermal cycles to achieve maximum particle to particle thermal conduction and for the heatsink to CPU interface to reach maximum conductivity. (This period will be longer in a system without a fan on the heatsink.) On systems measuring actual internal core temperatures via the CPU's internal diode, the measured temperature will often drop slightly over this "break-in" period. This break-in will occur during the normal use of the computer as long as the computer is turned off from time to time and the interface is allowed to cool to room temperature. Once the break-in is complete, the computer can be left on if desired.
這款有2.5G的小枝裝賣
我只用一次的話好像比較不會浪費
我是重裝CPU散熱器用的
這個有那麼耐用嗎?
因為好像有些會有油水分離的現象,
用一段時間後要換似的
還有,這個的有個特別說明,我不太明白
是指可以裝了塗了很立即用電腦
原文
Important Reminder:
