Aone Ultra Video Joiner 6.3.0103
  • 主題發起人 主題發起人 mikotoyou
mikotoyou
INFO
Aone Ultra Video Joiner 6.3.0103 | 10 Mb
Ultra Video Joiner is a professional video file joining tool which join or merge multiple video files into a large one like AVI Joiner, MPEG Joiner, WMV Joiner, RM Joiner, MP4 Joiner etc. The Movie Joiner supports so many video formats including AVI, Divx, XviD, MPEG, WMV, ASF, RM, MOV, 3GP, MP4, FLV, MKV formats.
You can add an unlimited number of video files to the list and easily rearrange their order if needed , then merge the videos files to AVI, Divx, XviD, MPEG, VCD, SVCD, DVD, WMV, MP4, FLV formats. You even can use it to convert a single file. It also supports join video files to VCD/SVCD image and DVD-Video files, so you can burn them into one VCD/SVCD/DVD disc easily by using third-party burning tools. It already includes all video encoders and decoders , you don't need to download any other codecs to make it work. With just a few mouse clicks, you can enjoy your movie clips without interruption.
Key Functions
* Join video files directly without re-encoding
You can use Ultra Video Joiner to join multiple AVI MPEG WMV MP4 FLV clips directly without re-encoding
* AVI Joiner - join AVI DivX video files
You can use Ultra Video Joiner to join multiple AVI DivX files with Fast conversion speeds because All encoders/codec are built-in
* MPEG Joiner
Ultra Video Joiner to join multiple MPEG1, MPEG2 files. A lot of settings you can tweak to achieve high quality.
* Join multiple videos to another format
Combine and join multiple video formats to one file with comprehensive video formats supported like DVD, VCD, SVCD, AVI, DivX, MPEG, ASF, WMV.
Key Features
* Super fast conversion speed provided as it full supports Intel Pentium D Dual-Core Processor and AMD Athlon™ 64 X 2 Dual-Core Processor which ensures full use of your CPU
* All encoders/codec are built-in and any supported conversion can be done once you downloading the software
* Join video files directly without re-encoding, very fast and without any quality loss
* Merge your favorite video files to another formt
* Join unlimited number of video files in different formats
* Cut unwanted parts by specifying start time and end time
* NTSC/PAL setting options for DVD, VCD, SVCD exporting
* Add letterbox to keep the original aspect ratio
* High conversion speed and wonderful output quality
* Support "Drag and Drop" from Windows Explorer
* Simple GUI and very EASY to use
* Lifetime FREE Technical Support and FREE upgrade. Free trial download. 30 day money back guarantee
Home Page - http://www.aone-soft.com
Download FileSonic
代碼:
http://www.filesonic.com/file/U82DNjq/
