AMD X6 1090T air clocking and ASUS Crosshair IV
  • 主題發起人 主題發起人 FlanK3r
FlanK3r
Hi, im from for you from exotic country Czech Republic in Europe. This forum sometimes im reading, but i must using google translator :D. Chinese language is very hard for us.
So...how good is 1015 DPMW series? I can show you on screens
CPU: x6 1090T BE
MB: ASUS Crosshair IV Formula
cooler: Xigmatek 1283 DK with Ultra Kaze fan
RAMs: 2x2 GB A-Data 2000X MHz cl9
GPU: ASUS HD5770 ucore 1GB GDDR5
PSU: Seasonic 650W bronze
Operation System: win XP Profesionall 32-bit, Win 7 Ultimate 64-bit
Begin in 32-bit system. 32-bit is more overclock friendly than 64-bit
First stability testing:
1.44V at CPU, 4226 MHz !
stability with 1.48 V, this was max chip stability, next higher voltage with higher clocks give me erorrs. So 4300 MHz air stable is not bad ;cheer2;
Now going to benchmarks:
superpi 1M at 4573 MHz, good? No, only quick run
here is my record with this chip from yesterday, under 15s ;face0;, run at 4628 MHz with 1.548V
So, some hardly bench-Cinebench R10. This bench is good for quick stability and to find some instability (bluescreens is mostly problem with RAMs or CPU-NB, black window is crash and warm at CPU)
4380 MHz Cinebench run
newest version know as Cinebench R11.5 at 4358 MHz
Quick run 3Dmark 2006, clock GPU was at stocks, C/U more than 4400 MHz
time to wprime :), 32M and 1024M
And max validation this chip? I was shocked, i used only safe 1.55V and...4814 MHz
Now we show at Win7 64-bit
. Here i tested only stability and some benchmarks, where is better scaling than 32-bit (mostly multithread rendering, you can compared Cinebench score here and in 32-bit XP)
max. stability "only" 4254 MHz, this is -50 MHz diferent again 32-bit
superpi 32M - i want under 15 minutes :), this will hard work
Cinebench R11.5, so close 7.7 points :)
I hope, this my first thread will like you. Best regards, FlanK3r
PS:srry for english
Nice OC'ing man~!!
Thanks for sharing. BTW, what's your temp. like when over 1.5v?
It's cool to see ppl from Czech tho~ and welcome to the most famous OC website in Taiwan!! :PPP:
thanx :)
With this cooler+ultra kaze and MX2 paste i had max 56 C in burn (1.48V). Ultra Kaze is in burn a bit loud, but highly performance. I tried more voltage between stability tetsing, but i have only errors. This chip is crazy, it has errors, but not freeze. With second PC (x4 965 build) i had temps wall, with Thuban not :)
Ouch, i thought, this is Chinesse, so, this is Taiwan web? U can look at czechPCwebs :)
http://extrahardware.cnews.cz/
http://pctuning.tyden.cz/
http://www.svethardware.cz/index.jsp
or www.cttl.cz
And here for us little big wallpaper ASUS Crosshair IV+Phenom X6 to download
http://www.edisk.cz/stahnout-soubor/05745/Wallpaper.rar_9.49MB.html
welcome !!:)
I have a question , this cpu's name is 1090T or 1095T ?I often see confused the two but these two are different ?Or just different parts of the model ?
Thanks;em03;
Welcome and...
Good OC!
Expect you to have more good OC test
erosyanch thank you :)
krnpcs This is really "only" x6 1090T, but CPU-Z show it not correct. Think, at 3-4Q we will see x6 1095T, it will 3.2 GHz hexacore, but with higher turbocore clock (500 MHz).
ds934118 yes, i benched some K8 chips, Phenom x3 8650, x4 9850 BE, x4 955 C2, x4 965 C3 (first OC experience was in fact Celeron Tualatin). And i can post more, give me time :-) (3Dmark05, Vantage, Fritzbench, winrar, Everest)
Thanks , your answer !:)
impressive,dude
Well I am rarely hands on the AMD system , but , I know this would be the hardcore bench for sure.
Nicely done and , certainly,
Very welcome to CBB:)
BTW, Mandrin is not that hard to understand,
you can learn from the some words such as English "F-words":D
Keep pushing up buddy:)
