【軟體名稱】:AIDA64 Extreme Edition 2.85.2400 Final
【軟體語言】:多國語言
【軟體分類】:系統檢測
【檔案大小】:14.3 MB
【檔案類型】:RAR壓縮檔
【解壓密碼】:***回覆後可見***
【官方網頁】:http://www.aida64.com
· 支援對各種處理器的偵測。
效能測試項目說明:
v2.85.2400 Final 更新紀錄:
* Optimized 64-bit benchmarks for AMD A-Series “Richland” APU
* Improved support for AMD “Kabini”, “Temash” and “Kaveri” APUs
* Improved support for Intel “Haswell” and “Valleyview” processors
* Preliminary support for AMD “Beema” APU
* Preliminary support for Intel “Avoton” SoC, “Crystal Well” CPU, “Haswell-E” CPU, “Haswell-ULT” SoC, “Ivy Bridge-E” CPU, “Lynx Point-LP” PCH, “Wellsburg” PCH
* Preliminary support for DDR4 memory modules and GDDR5 system memory
* GPU details for AMD Radeon HD 8000 Series and nVIDIA GeForce GTX Titan
