【軟體名稱】:AIDA64 Extreme Edition 2.50.2045 Beta
【軟體語言】:多國語言
【軟體分類】:系統檢測
【檔案大小】:13.9 MB
【檔案類型】:RAR壓縮檔
【解壓密碼】:***回覆後可見***
【官方網頁】:http://www.aida64.com
· 支援對各種處理器的偵測。
效能測試項目說明:
v2.50.2045 Beta 更新紀錄:
* Hardware Monitoring / new item: Display Brightness Level
* Display / GPGPU / support for nVIDIA CUDA 5.0
* Disk Benchmark / new test: Linear Write + Verify
* Disk Benchmark / new test: Random Write + Verify
* anti-virus software support for Windows Defender (of Windows 8)
* Intel Processor Number detection for Pentium G2100T
* RAID SMART support is now enabled by default
* GPU information for AMD FirePro V3900 (Turks)
* GPU information for AMD FirePro V4900 (Turks)
* GPU information for AMD FirePro V5900 (Cayman)
* GPU information for AMD FirePro V7900 (Cayman)
* improved motherboard specific sensor info for ASRock boards
* fixed: anti-spyware software support for Windows Defender (of Windows 8)
* fixed: Intel Processor Number detection for Core i3-3240T
* fixed: BSoD on Intel RAID controllers
