【軟體名稱】:AIDA64 Extreme Edition 1.80.1481 Beta
【軟體語言】:多國語言
【軟體分類】:系統檢測
【檔案大小】:12.7 MB
【檔案類型】:RAR壓縮檔
【解壓密碼】:***回覆後可見***
【官方網頁】:http://www.aida64.com
· 支援對各種處理器的偵測。
效能測試項目說明:
v1.80.1481 Beta 更新紀錄:
* temperature, fan speed, voltage correction
* Hardware Monitoring / new item: iGPU voltage
* anti-virus software support for Avast v5, v6
* anti-virus software support for Kaspersky 2012
* firewall software support for Avast Internet Security v5, v6
* firewall software support for Kaspersky Internet Security 2012
* improved support for Intel Xeon MP (aka Nehalem-EX, Westmere-EX)
* motherboard specific sensor info for Asus Maximus IV Extreme-Z
* fixed: BIOS settings detection via Asus ATK
* fixed: motherboard specific sensor info for Intel DP67BG, DZ68BC
AIDA64 Extreme Edition 1.80.1450 Final
查看最新更新
如無畫面顯示,請於畫面上點右鍵>編碼>Unicode(UTF-8)
請更新【WinRAR】【7-Zip】以確保解壓縮無誤
如果你覺得本軟體好用的話請點一下右下角的↘![]()
感謝支持!也別忘了支持正版唷!
