[台北售] NCase M1 V2 ITX 小鋼砲機殼 可上2D 水冷 體積超小
coolruehl
1.品名 : NCase M1 V2 ITX 小鋼砲機殼 可上2D 水冷 體積超小
2.數量 : 一組
3.品相及保固 :全新~當初多買一組
4.售價 :6500 北市自取 ~宅配+200
5.地點 :台北市(面交) 全省(宅配)
6.交易方式:可宅配,可面交
Specifications
See the compatibility tab for component size restrictions.
Dimensions (H x W x D): 240 x 160 x 328mm, 12.6L (250 x 160 x 338mm overall)
Motherboard support: Mini-ITX, Mini-DTX
Liquid cooling support: Single 120mm or 240mm slim radiator
Power Supply support: SFX, ATX (limited; see compatibility section)
Drives:
• 3 x 3.5" Mounts: ◦1 on case floor
◦2 in removable side bracket (cannot be used with dual radiator)
• 3 x 2.5" Mounts: ◦1 inside chassis front
◦1 behind front panel (in place of optical drive)
◦1 on case bottom (in place of 3.5" drive)
◦Included double-stacking bracket allows 2 x 2.5" drives on one mount (depending on drive thickness)
Disc Drive: Slim slot-load optical drive bay
Fans:
•4 120mm fan mounts
•2 on side bracket
•2 on case bottom (in place of 3.5" drive)
•1 x 80/92mm fan mount (bottom)
•1 x 80/92mm fan mount (rear)
Front ports: 2 x USB 3.0, HD Audio
Power button: Red/blue power/drive activity LED
Material: 1.5mm aluminum construction, anodized brushed exterior, painted interior
以下為官網圖
補充
該機殼由聯力代工~
品質很不錯!!
