RapidShare Downloader v4.21
  • 主題發起人 主題發起人 viet80
viet80
Info:
Downloader RapidShare, RapidShare.com than has been developed for an easy way to download files.
RapidShare.com links to the program by copying and pasting your list so you can create a simple way to download.
Now download files one by one, in order to download the file you download will not have to wait until the file, you want to download only the links to add programs, download RapidShare Downloader drown.
SIZE play games, watch movies, surf the Internet in your job to do and to keep interested.
PREMIUM able download the file using your account!
Trouble to see a list of the files that are downloaded!
RapidShare'den deleted and can not be downloaded to see a list of files!
Notes section and downloaded an encrypted password files, web sites and notes can be recorded!
Download list. TXT and can be registered as. TXT files to get the connection!
RapidShare Downloader is set to run automatically at Windows startup!
RapidShare Premium Downloader to download files to your account using the "Internet Explorer" and you must be logged in to your Premium account is sufficient.
1. As a premium user to download the file to be viewed using Internet Explorer adımlar.RapidShare Premium log in to your account. (Must use IE, Firefox, etc.. Not.)
2. RapidShare Downloader run.
3. "Premium Login" button.
4. 'Premium Login "window you'll see three buttons.
5. Premium Download operations as a user to continue the "OK" button.
PREMIUM-day limit expired, it will detect it and download RapidShare Downloader operations to continue as Free User.
Seamlessly downloaded to your installation folder and files that have been recorded, is now kept in a separate list. Those files may be downloaded by clicking on the list and double click the compressed files, you can open files directly. (WinRAR, etc. Must have a program installed on your computer.)
RapidShare'den not be deleted, and in the list of files to see!
While trying to download this section of the connection that was not deleted or RapidShare'den lists.
RapidShare servers sometimes gives an error if the file is not deleted, in this case the file will be listed in this section again.
That was not down to try to re-download files to the list, double-click the connection you want to add, row, your link will be added to the list.
RapidShare Downloader, each download process has finished downloaded the file completely and correctly downloaded I will check, if you downloaded the file is incorrect or incomplete downloaded the re-download list automatically by adding one more will be downloaded.
Notes section and downloaded an encrypted password files, web sites, and your notes can be recorded!
When downloading files, those passwords are encrypted, so the addresses of sites you use. You can write your notes on this section.
Download list. TXT and to register as. TXT files to get the connection!
When you download your list, click the drop-down list in the edit window with the new buttons to download your list. TXT records as may be, if you want too. TXT files again, you can get your download list.
With this new addition to the options settings window RapidShare Downloader automatically during Windows startup can be set to work.
RapidShare'den has never been so easy to download files
MajorShare.com - RapidShare Downloader; RapidShare.com than has been developed for an easy way to download files.
Now download files one by one, in order to download the file you download will not have to wait until the file, you want to download only the links to add programs, MajorShare.com - RapidShare Downloader download drown.
We also play games, watch movies, surf the Internet in your job to do and to keep interested.
Now much easier to add links!
RapidShare links to the program with two mouse clicks you can add!
For those of you just want to add a link and right click and select "Copy" or just click.
RapidShare download all the selected links will be automatically added to your list! If you want this feature to "Settings" section you can cancel.
Languages supported
Turkish, Türkçe, Deutsch, French, Romanian, Portuguese, Swedish, Spanish
MSINET.OCX issue and others. OCX problems.
For Vista users do not encounter these errors;
* Table top your "RapidShare Downloader" icon, right click and run the program as an administrator.
RapidShare Downloader OCX errors may first start it after installation, in this case, try running again a few times RapidShare Downloader.
代碼:
Download Link:
http://rapidshare-9.blogspot.com/2010/04/part1_9892.html
No Pass
