Q9xxx WITH Asus Maximus Formula 超頻FSB BUG
來到台灣的討論區麻煩請用回書面語Orz
以我所知很多4核都存在不能跑高FSB的問題 450有瓶頸是很正常說...
聽某高手說可以透過降北橋電壓來達至更高的FSB...但我沒證實
來到台灣的討論區麻煩請用回書面語Orz
但我用同樣的cpu ram 在其他地板可以上450 fsb 上..
別用 1:1,換 5:4 看看,我自己也是用 MF,1:1 怎麼調都過不了,調 5:4(FSB 450,RAM 1128) 反而很穩,不過當然要看 ram 的體質。
你是用q9450的嗎??
可以貼一下你的電壓圖嗎?
請post你的bios setting @o@
Extreme Tweaker
Ai Overclock Tuner : Manual
OC From CPU Level Up : AUTO
CPU Ratio Control : Manual
- Ratio CMOS Setting :
FSB Frequency :
FSB Strap to North Bridge :
PCI-E Frequency:
DRAM Frequency: DDR2-
DRAM Command Rate :
DRAM Timing Control: Manual
CAS# Latency :
RAS# to CAS# Delay :
RAS# Precharge :
RAS# ActivateTime :
RAS# to RAS# Delay :
Row Refresh Cycle Time :
Write Recovery Time :
Read to Precharge Time :
Read to Write Delay (S/D) :
Write to Read Delay (S) :
Write to Read Delay (D) :
Read to Read Delay (S) :
Read to Read Delay (D) :
Write to Write Delay (S) :
Write to Write Delay (D) :
DRAM Static Read Control:
Ai Clock Twister :
Transaction Booster :
CPU Voltage :
CPU PLL Voltage :
North Bridge Voltage :
DRAM Voltage :
FSB Termination Voltage :
South Bridge Voltage :
Loadline Calibration :
CPU GTL Reference :
North Bridge GTL Reference :
DDR2 Channel A REF Voltage :
DDR2 Channel B REF Voltage :
DDR2 Controller REF Voltage :
SB 1.5V Voltage :
NB LED Selection : NB Volt
SB LED Selection : SB Volt
CPU LED Selection : CPU VOlt
Voltiminder LED :
CPU Spread Spectrum : Disabled
PCIE Spread Spectrum : Disabled
Advanced CPU Configuration
C1E Suppport : Disabled
CPU TM Function : Disabled
Vanderpool Technology : Disabled
Execute Disable Bit : Disabled
Max CPUID Value Limit : Disabled
USB Configuration
USB Functions: Enabled
Legacy USB Support : Disabled
