軟體名稱 :Print2cad 檔案轉換器
檔案大小:125.32MB
檔案格式:ZIP
上傳日期:2015-11-25
解壓縮密碼:無
下載: Print2CAD 2016 2.zip
內容簡介:
Print2cad 是一個檔案轉換器,它可以讓你把 PDF, PDF/A-, DWF, TIFF, JPEG, PLT (HPGL)
和 EPS (PostScript)檔案轉換成DWG, DXF 或 DGN 格式檔案,然後將其匯入到任何版本
CAD的系統。 Print2cad 是一個獨立的程式,可以獨立運作在所有的CAD系統上。您不需要
AutoCAD或任何其他的CAD程式運行Print2CAD 。
Print2CAD 2016 7th Generation 14.51.0.0 | 125.32 MB
Print2CAD 7th Generation is able to convert PDF files into a DWG or DXF file, which can then be imported into any CAD system where it can be edited. Print2CAD 7th Generation is an autonomous and CAD system-independent program. Print2CAD 8th Generation also converts DWG/DXF into PDF, TIFF/JPEG into DWG, DWF into DWG/DXF and HPGL into DWG/DXF.
Top CAD Converter! PDF to DWG and More!
PDF to DWG/DXF, OCR of Text, Raster To Vector, Calibration of Coordinates with Calibration Points, Raster To Solid, Line Type Recognition, Layer Recognition, Vector Optimization, File Size Optimization, Text Hight Optimization, Cropping of Details, Digital Photos Contourization, Scan To Vector, Symbol Recognition, Smoothing of Polylines, Repairing of Scans, 3D PDF Support.
Software Features:
■ Print2CAD Features AutodeskR TrustedDWG? Technology
■ DWG and DXF output with 100% AutodeskR Compatibility
■ Print2CAD Features OCR (Optical Character Recognition) Technology
■ Print2CAD Features English and German as Native Languages and Units
■ Print2CAD Features English, German, Spanish, Italian and French Interfaces
■ Contains DWG and DXF Structure Viewer DeepView 2016
■ Contains PDF/ DWF/ TIFF/ JPEG / HPGL Viewer PVGview
■ Assistant for Easy Conversion
■ OCR Recognition of PDF / TIFF / JPEG / DWF / HPGL Text
■ Coordinate Calibration with Free Calibration Points
■ Line Type Recognition
■ Vectorization of PDF raster images black / white or color
■ Vectorization of TIFF, JPEG raster images black / white or color
■ 28 Training Video Clips
■ PDF and Multimedia Reference Manual
■ Text Height Normalization
■ Vectorization Expert Settings
■ PDF to DWG or DXF Conversion (for all CAD systems)
■ DWG to 3D PDF Conversion (with new PRC Format)
■ PDF to JPEG / TIFF Conversion (LZW, G4, G3)
■ PDF to JPEG, TIFF, GIF, PNG Conversion
■ TIFF / JPEG / BMP/ PNG/ GIF to DWG/DXF Conversion (for all CAD systems)
■ DWF/ EPS/ PS/ PostScript to DWG/DXF Conversion (for all CAD systems)
■ DWG/ DXF to PDF conversion
■ HPGL and HPGL-2 to DWG or DXF conversion (for all CAD systems)
■ Command Line and Batch Support
■ Conversion into DWG and DXF Version 12, 14, 2000 to 2016
■ Support of PDF Text
■ Support of PDF Layers
■ Extraction of PDF Pixel Images as JPEG or TIFF Files (optional)
■ Recognition of Circles and Arcs
■ Rotation and Scaling of DWG and DXF Coordinates
■ Purge and Merge Polylines
■ Reconstruction of DWG and DXF Layer Structure
■ DWG and DXF RGB Color conversion
■ Start with thousands of PDF, HPGL, TIFF, JPEG, DWF Files in One Run
■ High precision of DWG or DXF Coordinates
■ Optimization of Polylines
■ Convert all PDF Pages into Separate DWG or DXF
■ Assign PDF Line Weight to DWG or DXF Entities
■ Extract embedded raster images from PDF as BMP, JPEG, PNG or GIF
■ Convert embedded raster images from PDF as Solids or Lines
■ Supports TIFF and JPEG Vectorization
一切後果將由您自己承擔!
2. 僅供個人測試無販售行為及獲得任何利益!!
3. 凡交流會員請於下載後24小時以內將檔案刪除!!
4. 滿意者請購買正版並尊重智慧財產權!!
5. 如作為其它用途,皆與作者無關!
檔案大小:125.32MB
檔案格式:ZIP
上傳日期:2015-11-25
解壓縮密碼:無
內容簡介:
Software Features:
一切後果將由您自己承擔!
5. 如作為其它用途,皆與作者無關!
