PdfFactory Pro 3.5 Full
  • 主題發起人 主題發起人 viet80
viet80
Info:
Create PDF or print to paper: Only pdfFactory allows printing to paper or PDF without printing twice. Acrobat is not needed for printing.
Combines multiple documents into a single PDF: Increases the convenience of document delivery by having a single PDF that contains material from different sources. Just keep printing documents to pdfFactory and they will automatically be combined.
Preview: Allows quick, accurate previewing of the PDF, including up to 400% zoom, without saving the file first and without opening Acrobat.
-Security: Encrypt and control access to PDF files as follows:
-Prevent printing PDFs
-Prevent copying text and graphics
-Prevent opening without a password
-Prevent editing (yes, PDFs can be edited)
-Font embedding: Ensures that the original fonts used in a document are displayed even if the reader of the PDF does not have the fonts installed on his or her computer.
-Page insertion and deletion: Allows unwanted material to be deleted before the PDF is created. This is especially useful when creating PDFs from long reports, email and web pages.
-Send via email: One mouse click sends PDFs through your default email program. Also copies PDF to clipboard for pasting into existing email.
-AutoSave: Saves entire contents of pdfFactory sessions automatically so you can retrieve previously compiled PDFs.
-Live URL Links: Customize links by line type, thickness and color to open Web pages and email addresses with a click of your mouse.
-Create PDFs on letterhead
-Add page numbering, headers, footers, watermarks
-Bookmarks and Table of Contents: Automatically or manually create bookmarks to organize and easily navigate complex documents.
-Convert to grayscale
-PDF/A-1b archiving support
-Integrated Jobs Tab: Shows all jobs and allows you to rearrange them.
-Custom Drivers: Save your settings to multiple print drivers so you can quickly select them for specific tasks.
-Set Initial Acrobat Display Properties: Such as zoom factor, layout and tab configuration.
代碼:
Download Link: (Rapidshare)
http://rapidshare-uu.blogspot.com/2010/06/pdffactory.html
No Pass
