MSI Afterburner 2.1.0 Beta 7 正式支援GTX560 Ti / GT440、免改BIOS解除CCC超頻上限並保留PowerPlay
  • 主題發起人 主題發起人 eLove
eLove
MSI Afterburner 2.1.0 Beta 7 (2011-01-31)
載點:http://downloads.guru3d.com/Afterburner-2.1.0-Beta-7-download-2604.html
更新記錄:
- the official support of GTX 560 Ti / GT 440.
- Now Microsoft Visual C++ 2008 runtime libraries are included in distributive
- Hardware database is now configured to force fan duty cycle monitoring to be performed via slower AMD ADL SDK path on AMD RADEON 4870 X2 and 5790 series cards
- Changed way of unlocking unofficial overclocking on AMD graphics cards to make overclocking newbies think harder before enabling this functionality blindly and coming to support forums with fake bugreports
- Added alternate unofficial overclocking path allowing keeping PowerPlay active on some modern ASIC families during overclocking
- Fan control settings are now being forcibly reapplied after changing the clocks via unofficial overclocking path to bypass bug in AMD driver causin the fan control settings to be reset to defaults after programming PowerPlay table
To enable unofficial overclocking in this version it is necessary to:
- Set UnofficialOverclockingEULA field to the following text: I confirm that I am aware of unofficial overclocking limitations and fully understand that MSI will not provide me any support on it
- Set UnofficialOverclockingMode to 1 to keep PowerPlay active (may not work on old ASICs), 2 to traditionally disable PowerPlay or to 0 to temporary disable unofficial overclocking path
請開啟安裝資料夾內的 MSIAfterburner.cfg,按下圖修改 UnofficialOverclockingEULA、UnofficialOverclockingMode 兩個設定值
UnofficialOverclockingMode= 0 ---> 關閉 UnofficialOverclocking
UnofficialOverclockingMode= 1 ---> 在UnofficialOverclocking狀態下開啟 PowerPlay 功能
UnofficialOverclockingMode= 2 ---> 在UnofficialOverclocking狀態下關閉 PowerPlay 功能
核心與記憶體時脈最大值
超頻後,PowerPlay 的狀態的確是開啟的
PS:
其實這功能在新的beta會開放有點意外就是 ...
因為之前有個白目user在吵為何 Sapphire TRIXX 可以做到而 MSI Afterburner 做不到
搞到最後作者放狠話,他說論壇帳號可以不要,不再繼續發言
接著有篇主題直接投票到底需不需要作者 :PPP:
不過後來工作在忙就沒追蹤事件發展
剛剛很意外的發現這功能竟然開放,不必再改bios直接解除CCC超頻上限還保留 PowerPlay :MMM:
現在才能調電壓阿
我6950都賣掉了說
等過完年再買一張來玩玩~
哪個白目再吵啦= =
微星這款不錯用說= =
終於可以無視BIOS了...
哦~這個軟體好..
可以準備對我的GTX560下手OC到爆
就可以免費換新的囉
感謝大大的分享與資訊;em28;
為啥我6850不能調電壓
