Question:
1: What is MTS video?
2: How to convert MTS video
Answer:
1: MTS is the raw file of AVCHD video. MTS format is a high-definition MPEG, AVC, H.264 transport stream video file format which commonly used by HD camcorders such as Sony, Canon, Panasonic. Camcorders make use of MTS in the form of AVCHD, a recording format made specifically for camcorders..
2: Now there is one professional
MTS Converter-Tipard HD Video Converter, which is fast MTS file converter to convert HD video to general video, convert general video to HD video, convert among HD videos, such as HD TS, HD MTS, HD WMV, HD MPG, HD MPEG4, H.264/AVC , HD AVI, HD ASF, etc at fastest speed and excellent image/sound quality with least quality loss.
Do you want to enjoy HD videos? Here you can get your wonderful experience.
Step 0:Install and run MTS Converter
Step 1: Add file to MTS Converter interface. There are three ways to put your files on it.
Method One: Click "Add File", it would pop up one window, and select you want to convert file on this window.
Method Two: At the top of the drop menu, click "File", then select "Add File" to import your HD video and other video or audio files.
Method Three: Drag the file to Tipard MTS Converter interface directly
Step 2: Choose profile
This MTS file Converter places the profile in order, and sorts it by General video, General audio, HD videos, Xbox, PS3 /PSP, Apple TV, iPod, iPhone, Wii, Lossless Audio, Mobile Phone, Animation, Portable Multimdia Devices, Zune, Google Phone, PDA(Windows Mobile), User-defined. After you select the profile, continue to select the format on the right drop menu.
Step 3: Click the "Start" button to start your conversion.
Just wait a moment, then your conversion will be finished.
Some powerful functions such as "Merge", "Trim", "Effect", "Snapshot", "Crop" are all available.
HD Converter support all kinds of input file(video, audio and HD video) formats, and all kinds of output file(video, audio and HD video)formats. You can playback converted files on your ipod series, iphone, iphone 3G, Apple TV, Zune, PSP, Pocket PC, Creative Zen and suchlike PMPs.
Now hurry up to have a try this HD converter, I believe you will get a fun. Enjoy it.
M2TS Converter
TS Converter
Answer:
M2TS Converter
TS Converter
