hard drive question
  • 主題發起人 主題發起人 kayliu
kayliu
i was put the old hard drive(SATA) which contains the old data from the old pc(window XP), and put it into the new computer (vista 32bit) after computer ran about 2 minutes the computer automatic shut down. Then i turned the computer back again then the old hard drive did not work ever again. did i do something wrong?
old hard drive WILL OUT OF ORDER 簡單來說.硬碟快掛了
I do not think so, the hard drive is not the reason caused pc restart, you can try to scan the old hard drive in different pc. what will happen if you start the new pc without old hard drive?
您还是把自己的配备列清楚,是看不到旧的硬盘.还是重新启动PC, 硬盘连转的声音都没有,那样硬盆就挂了.
您还是把自己的配...
but why my hard drive will died like this?
VGA EVGA 320-P2-N811-AR 8800GTS
Seagate Barracuda 320GB Hard Drive SATA 3Gb/s, 16MB Cache
Intel Core 2 Duo E6750
ASUS P5N-E SLI Socket 775 Motherboard, nForce 650i
ULTRA power supply 600watt
Corsair 2gb ddr-800 6400
