Updated Media Player Classic (version 6.4.9.0+ SVN build 2006-10-16)
Updated ffdshow to revision 486
Updated DivX decoder to version 6.2.5.34
If you have stability issues with the DivX decoder, then don't install it or disable it via the Codec Tweak Tool and use ffdshow instead
Updated DivX encoder to version 6.4.0.51
Updated Xvid to version 1.2.0-dev build 2006-11-02
Updated x264 VFW to rev. 578
Updated AC3Filter to version 1.11
Updated RealMedia components to version 6.0.12.1741
Updated Haali Media Splitter to version 1.6.338.23
Updated Cyberlink MPEG decoder to version 6.0.0.3402
Updated Cyberlink MPEG demuxer to version 1.0.0.4528
Updated FLAC to version 0.73.1936
Updated LAME MP3 ACM to version 3.97
Updated LameDropXPd to version 3.97
Updated LAME CLI to version 3.97
Updated OggDropXPd to version 1.8.9 aoTuVb5
Updated DirectVobSub. This should fix a (rare) problem with green lines on some divx files
Updated GSpot to version 2.60 beta 3
Added .asf file association option
MPC will now play 3GP files using DirectShow filters (MP4 splitter + ffdshow) instead of QuickTime
ffdshow is now used by default to decode Xvid video
Added option to create a System Restore Point at start of installation
Improved compatibility with Windows Vista
Download Link
Download Link
