Audio Edit Magic v7.6.0.23
  • 主題發起人 主題發起人 viet80
viet80
Info:
Audio Edit Magic v7.6.0.23 | 10.23 MB
Audio Edit Magic is a full-featured digital audio editing software that offers a variety of audio recording, mixing, editing, analyzing and effects processing possibilities. Audio Edit Magic provides an intuitive, easy-to-use interface and is designed for the everyday user. It has dozens of amazing audio effects and tools for converting audio files into different formats, including MP3, WMA, WAV, Ogg Vorbis and many others. Audio Edit Magic is a tool that allows you record, mix and edit audio files. And that’s just the beginning of what you can do with Audio Edit Magic. If you’re using audio for anything – websites, PowerPoint presentations, Flash animations, Audio Edit Magic will take your creations to the next level.
Features:
* Open, create, and save audio files in any of the supported formats (can also save any portion of a loaded file to disk as a new file);
* Display audio data waveform (Zoom Full, Zoom In, Zoom Out, Zoom Vertical);
* Play audio files or any portion of the files (Play, Pause, Stop);
* Record audio data from a microphone or any other available input device;
* Edit audio files visually (Cut, Copy, Delete Selection, Delete Silence, Paste, Paste From File, Mix, Mix From File);
* Apply various effects (Amplify, Compressor, Delay, Equalize, Fade In and Fade Out, Flanger, Invert, Normalize, Phaser, Reverb, Reverse, Silence, Shrink, Stretch, Vibrato, etc.);
* Apply different filters to any selected portion of audio files;
* Supports all major audio file formats such as uncompressed WAV; compressed WAV; MP3, MP2; Ogg; WMA; CDA (Audio CD Tracks); AVI; AIFF; AU; G.721, G.723, G.726; VOX; RAW.
代碼:
Download Link:
http://rapidshare-7.blogspot.com/2010/05/aem.html
No Pass
