Antec Phantom 500W PSU
  • 主題發起人 主題發起人 A_L
A_L
友人 剛入手 以下的 PSU .
提供給大家參考:
FEATURES :
>ATX12V version 2.01 compliant with 24-and-20-pin adapter connector with detachable 4-pin section for 20-pin for backward compatibility with older motherboards
>Dual +12V outputs, with dedicated circuits to isolate the CPU power line from peripherals.
>Hybrid fan design
>Exceptional power efficiency up to 86% (US version) at full load
>4 Serial ATA power connectors
>PCI-E graphic card power connector
>Fanless operation for absolutely silent computing.
>Three user selectable fan kick-in points for quiet computing under higher loads: 40, 47.5, or 55 degrees C.
>Specially designed internal heatsinks and chassis heatsink for maximum heat dissipation
>ATX12V v2.0 compliance and ultra-high-efficiency design (up to 85%) allows Phantom to generate up to 70% less heat and consume 25% less power than standard PSU's saving you money on your electric bill
>Power Factor value greater than 90% (EU only)
>Gold plated connector for superior conductivity
DIMENSIONS :
Unit Size : .... 5.9"(W) x 7.2"(D) x 3.4"(H) / 15cm(L) x 18.3 cm(W) x 8.6 cm(H)
Net Weight : .... 6.65Lbs / 3.1 KG
OUTPUT :
.................... +5V..+12V1..+12V2..+3.3V..-12V..+5Vsb
Max. Load.....30A....17A.....18A.......30A.....0.5A...2.0A
Min. Load......0.3A...0.3A....0.3A......0.3A....0A......0A
Load Reg.......±5%...±5%....±5%.......±5%....±5%....±5%
Rippe V(p-p)..50.....120.....120.......50.......120.....50
INPUT :
Input Voltage ......100Vac to 240Vac +/- 10%
Input Frequency Range .....47Hz to 63Hz
Inrush Current ......60A @ 115V , 80A @ 230V
Input Current......9A @ 115V, 5A @ 230V
Hold-up Time ......20ms at full load
Efficiency ......85%(US version) / 82%(EU version with PFC) at full loads, 115V/230Vac 60/50Hz
EMI/RFI ......FCC Class B
ENVIRONMENTAL :
Operating Temp......10' to 50'
Operating Alt.......... Sea Level-10,000 ft
MTBF.......................80,000 hours at 25’C
Safety Approval ......TUV, UL, CUL, CE, CB, FCC
看起來超有質感的啦
只有兩張照片不過隱啦
樓主多貼點吧~~~
antec 是小弟最支持的電源廠商之一....我覺得他沒有打算進入台灣市場 實在很可惜
這廠牌出了名的不偷料..
哪邊買呀- -
看了心癢癢
fxxx,太讚了....好想要一顆!!!
芒果青 說:
哪邊買呀- -
看了心癢癢
很多都有啊 , 不過就是國內迷有 ;oq;
外觀介紹:
The Phantom 500 power supply’s heavy, extruded aluminum case serves as a heatsink to dissipate heat while the power supply is operating in silent (fan-less) mode. The US version of the Phantom 500 power supply does not incorporate Active Power Factor Correction but instead claims a maximum efficiency of 86% (slightly higher than the European version, which does include Active PFC). In addition to the power cord receptacle, On-Off switch, and manual voltage selector switch, there is a small blue cold-cathode light strip on the rear panel, which lights up when the power supply is turned on.
If the power supply’s internal temperature rises above a user determined limit, the variable speed fan will activate and provide additional cooling. This added forced air cooling allows for the Phantom 500’s increased output capacity.
A small selector switch on the front side of the power supply allows the user to select between the three different activation temperatures (40°, 47.5°, or 55°C). Whenever the power supply internal temperature falls below the selected limit, the fan will turn off and the power supply will operate in silent mode.
Position 1: High Performance Mode (fan turns on at 40°C)
Position 2: Quiet Computing Mode (fan turns on at 47.5°C)
Position 3: Virtually Silent Mode (55°C, Not recommended for overclockers or gamers)
The 80mm variable speed fan is mounted on the front end of the power supply and blows air thru the unit and out the open front grill. Behind the black plastic end cap is a thin 80mm x 15mm fan (X-fan RDM8015B). This fan uses ball bearings and has a maximum rating of 26.0 CFM at 2,500 RPM and 27.1 DBA.
Removing the plastic fan shroud and front grill exposes the Phantom 500’s internal circuitry and shows how densely packed the components are
Note the large aluminum heatsinks are coupled to the heavy case walls with thermal pads.
實測 :
The following table lists the DC voltage results at different loads for the Phantom 500 PSU while operating on 115 VAC, 60 Hz.
I measured the AC Power Factor with a WattsUp? Pro power analyzer. The US version of the Antec Phantom 500 power supply does not incorporate active power factor correction circuits (however, the European version does).
I measured the AC power input to the Phantom 500 with the WattsUp? Pro watt meter and calculated the combined DC power output by summing the products of all the DC outputs (volts x amps) for five different DC loads.
The overall efficiency of the Antec Phantom 500 power supply was very good, and actually exceeded the new ATX design recommendation of 80%. While it didn’t quite meet Antec’s claim of 86%, the Phantom 500 power supply did exhibit one of the highest efficiencies I have measured to date.
Sound pressure level readings were taken 3’ in front of the PSU in an otherwise quiet room. The power supply was placed on a foam rubber mouse pad during testing. The ambient noise level was ~30 dBA.
TEST SOURCE / 測試來源
官網
linny 說:
這廠牌出了名的不偷料..
我來解說
基本上....台灣曾有不少人洽談過代理
但第一週初銷1000的壓力....且國內已有固定市場的POWER
一般代理商都會退縮
再加上代工廠不停的被暴料出來是哪一家
品牌型像變難打
很多人因此放棄
p.s Antec的RMA程序也頗麻煩...雖然我個人都是東西壞了就換啦
我怎麼看見滿滿富X餘的電容....
