You gotta be kidding me, this power is the best power I have never seen.
Powerful and smart unit ever.After did the simple bench, I am so so impressed with it's value
and power.
Let's check the official specifications of this great PSU.
It also can be found at zippy webpage :
http://www.zippy.com.tw/P_product_detail.asp?
lv_rfnbr=1&pp_rfnbr=1312&pcp_rfnbr=18&pp_name=&pcp_name=3U%
20Single&pcpw_rfnbr=6&pp_code=P3M-9950P
Output wattage: 950w
Best solution for : Server,Workstation,Storage System,IPC,Communication
Dimension:300.00x100.00x127.00 (mm)
11.81x3.93x5.00 (inch)
pretty long but not as wide as normal ATX power factor.
AC input spec.:
VOLTAGE: 100V ~ 240VAC (WITH ± 10% TOLERANCE)
FREQUENCY: 47Hz ~ 63Hz
INPUT CURRENT: 10A/5A AY ANY LOW/HIGH RANGE INPUT VOLTAGE
INRUSH CURRENT: 140/160A @ 110/220VAC (25℃)
POWER FACTOR CORRECTION: 95% @ 230V, FULL LOAD
DC output:
Features:
‧TEMPERATURE RANGE: OPERATING: 0℃ --- 40℃ STORAGE: -20℃ --- 80℃
‧HUMIDITY:OPERATING:20%-95%, NON-OPERATING:10%-95%
‧REMARKS:85% IS NORMAL CONDITION AND 95% IS WITH SPECIAL COATING PROCESS
‧HOLD UP TIME: 16 ms MINIMUM AT FULL LOAD & NORMAL INPUT VOLTAGE
‧DIELECTRIC WITHSTAND: INPUT / OUTPUT 1800 VAC FOR 1 SECOND
INPUT TO FRAME GROUND 1800 VAC FOR 1 SECOND
‧ EFFICIENCY: 70% TYPICAL AT 115VAC FULL LOAD
‧POWER GOOD SIGNAL: ON DELAY 100 ms TO 500 ms, OFF DELAY 1 ms
‧OVER POWER PROTECTION: 110% ~ 150%
‧OVEROVER VOLTAGE PROTECTION: If an over voltage fault occurs,the power supply will
latch all DC output into a shutdown state.
‧EMI NOISE FILTER: FCC CLASS B CISPR22 CLASS B
‧SAFETY: UL 1950, CSA 22.2 NO/ 950, TÜV IEC 950
‧REMOTE ON / OFF CONTROL
THE UNIT SHALL ACCEPT A LOGIC OPEN COLLECTOR LEVEL WHICH WILL DISABLE /
ENABLE ALL THE OUTPUT VOLTAGE (EXCLUDE +5V STANDBY),
AS LOGIC LEVEL IS LOW, OUTPUTS VOLTAGE WERE ENABLE,
AS LOGIC LEVEL IS HIGH, OUTPUTS VOLTAGE WERE DISABL
So what you think? lol..
Let's see some real monster here.
1. The power:
compare with pc p&c 1kw:
2. the whole thing includes molex:
4x sata; 1 24 pins atx , 12x 4 pins molex; 2 floppy molex. 1 x 8 pins atx12v and 1x 4pins
atx12v.
3. Backside , see the Delta? after i power it on, i guarantee no one can act like "it's ok, not
really loud." I just can't bear it at all.
so, you checked the number, you saw the pictures...wanna check how it performed?
check the classic psu bench, OCCT
each rail,
1. 3.3v
2. 5v
12v
cpu temp:
vcore:
quite a good result, during the run, those voltage looks like "lock up" never change.
certainly, we can't omit super pi 32m..
during the run:
What can I say? you will never know its good until you really touch that.
and power.
AC input spec.:
DC output:
Features:
1. The power:
atx12v.
each rail,
1. 3.3v
2. 5v
12v
cpu temp:
vcore:
during the run:
