自組新機錯誤訊息..help
  • 主題發起人 主題發起人 cupid
cupid
A problem has been detected and widnows has been shut down to prevent damage to your computer
if this is the first time you've seen this stop error screen, restart your computer . if this screen appars again, follow these steps:
check to be sure ou have adequate disk space. if a driver is identfied in the stop message, disable the driver or check with the manufacturer for driver updates . try changing video adapters.
chenk with your hardware vendor for any bios updates . disable bios memory options such as caching or shadowing . if you need to use safe mode to remove or disable compoents., restart your computer press F8 to select advanced startup options, and then select safe mode
****stop: 0x0000007E (0xc0000005, 0xf7749f08, 0xf7c7a000, 0xf7c79dcc)
*** pomcia.sys - address f7749f08 base at f7737000, datestamp 41107d31
以上錯誤訊息..是小弟最近組裝一台機器所出現的訊息..不知各位有愈過或是可幫個忙的嗎???
機器配備如下
cpu : 散佈龍 2400+
M/b : 青雲KX600A-GE BIOS版本 R1.00
顯示卡 青雲 5200EQ 256MB
RAM : 金士頓 512DDR 400 *2
PS:好家在那些錯誤訊息是英文...幾分鐘打出來..要是中文我應該會打死吧..........麻煩大家研究一下怎解決唷....謝啦
http://www.coolaler.com/ipb/index.php?showtopic=137
7 0x0007 儲存體控制區塊已毀。
建議閣下可從記憶體方面開始著手查問題......
其實不一定是記憶體損壞啦.....中古機、老電腦之類有時只要重插個一次就好了 :ph34r:
7 0x0007 儲存體控制區塊已毀。
感謝您的回應...^^
我同時買了2條 金士頓 DDR 400 512MB
這張主機板有3個dimm
我單條個別都測試過...是都沒問題...但就是插上2條..就有問題
至於為何會知道有問題..我是用prime 95燒機測試的
1.small ffts (maximum FPU stress date fits in l2 cache ram nit tested much)
2.in-place large ffts (maximum heat power consumption some ram tested)
3.blend tests some of everything lots of ram tested
我第一種2條ram都插下去一起跑測試都沒問題..
跑第二個跟第三個..跑幾分鐘就當了
但是我單條測試3種...也都OK...正常不會當
