(轉貼)SuperCache II v1.1.14.0
  • 主題發起人 主題發起人 hu10us22
hu10us22
軟體版本:
1.1.14.0
語言:
英文
作業系統:
Windows XP Home and Professional (32- & 64-bit)
Windows 2000 Professional
軟體簡介:
Supercache II這個軟體最主要的功能就是幫硬碟做cache的動作,
你可以把他想成是硬碟的快取,
目前市面上的硬碟快取主要為8MB,
用這個軟體你記憶體有多大就可以用多少喔,預設值是128MB
如果記憶體不大,建議只對windows安裝的槽做128MB的快取就好了~
Supercache簡單設定方法:
1.先安裝好重開機
2.在我的電腦裡面,把你要cache的磁碟按右鍵選內容
3.再選Performance
4.點SuperCache II...會出現目前狀況
5.點Start...來設定
Cache page size一般來說不太需要動他,選大一點會有比較好的效能,
但是空間使用上會比較浪費
Cache size要使用多少記憶體來當cache,
最大值請勿超過實體記憶體開機以後所剩下的量,不然會反效果
Sort algorithm換頁演算法,MRU比較省CPU資源,MFU則可能會有比較高的擊中率
Read-ahead通常5個應該就夠了
Defferred-write就是所謂的write-back,可以提高寫入效能,不過如果當機,
會導致資料流失,通常建議不要使用
設定完以後點ok就完成啦
序號:
name : for 9down by opossum
SN : M1X46-KXXKZ-Q42BP-LR1TV-41WBQ
Hinet載點
官方下載頁面
PS:發佈此帖是因為小弟用Google搜尋到的都是v1.0.12.0的版本,有裝過的人來更新版本吧~
這有一個移除SuperCache II的方法,為一個好心人士寫E-mail去問的,不過是英文,
小弟有看沒有懂>"<,希望有好心人士能翻成中文,:D
Hello,
I'm sorry to hear of your problems uninstalling SCII. I am not sure
why the product won't uninstall, but here are some steps to follow that
might be helpful.
The easiest and safest thing to do is to look for a restore point in
Windows that was created just before you installed our product. If you
can revert back to that point, that would ensure that all traces of SCII
will be removed. If this is not possible, I have some manual steps for
you to try to manually eliminate SCII from your system. They are as
follows:
Before you attempt these, please create a manual restore point on your
computer!
1) Open a command prompt window,
2) Change directory to the %ProgramFiles%\SuperSpeed\scsv folder,
3) Enter the following command "sscvfisx -d",
4) Close the command prompt window.
At this point, you should try to reboot your system and make sure SC is
gone.
If that still does not work, there is one other registry key that will
need editing. Before doing this, you should restore back to the
restore point you created just before the previous set of instructions.
Then, repeat those instructions and do the following as well:
1. On the task bar click "Start\Run...", and enter "regedit" in the
text box.
2. In the left page of RegEdit, open the key
"HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows\CurrentVersion\Uninstall".
3. Right click on the sub-key "{5B14E06B-97A1-11D3-B2C8-00C0F014C0F2}",
and click "Delete". Make sure you have selected the correct sub-key. If
so, confirm the deletion.
4. Close RegEdit.
I know these instructions are a bit long, but they should allow you to
Regards,
Marcie Tardiff
support@superspeed.com
感謝分享:PPP:
感謝分享
很多人蠻推薦的,謝謝分享....研究中...
謝謝提供新版的訊息,我現在還在用SuperCache II V1.0.12.0。
建議記憶體2G以上的人,搭配這兩套軟體(Ramdisk,SuperCache II)使用。
感謝分享^^
下載來試試看
感謝分享~
真的有差,不錯用阿!
啊!?
我以為這個是可以取代RamDisk的東西說...
512m不知道可不可以用,
試試看再說,感謝分享!!
