1.品名: IOGEAR 4 埠 USB 2.0 + 3 埠 Firewire 1394 複合集線器 (GUH420)
2.數量 : 1
3.品相及保固 :外觀9成9新,購買約3個月,原廠3年保固中
4.售價 :950元 (不含運費,誠可小議)
5.地點 :台北,新竹約時地面交,其餘地區請自加運費
6.交易方式:面交,郵寄或宅配
原來拿來接多顆USB/1394外接周邊,使用沒幾次,因現在外接周邊較少,用不到故出售
讓給有需要的人~
台北可周一至周五自取,新竹限平日晚上及假日自取,其餘地區請自加運費.
意者請留聯絡電話至email,將會主動與您聯絡,謝謝!!
email: lioyang@yahoo.com.tw
產品規格如下:
http://www.iogear.com/product/GUH420/
Description
The USB 2.0 / FireWire Universal Hub offers a complete high speed connectivity solution at a fraction of the cost of other separate USB 2.0 and FireWire Universal Hubs. It brings USB 2.0 and FireWire connectivity to your notebook or desktop computer. You'll enjoy the convenience and reliability that has made USB and FireWire industry standards when it comes to connecting multiple high-tech peripheral devices. USB 2.0 and FireWire provide high bandwidth, thus broadening the range of peripherals that may be attached to your computer. Features
FireWire
Three up/downstream ports
400 Mbps data throughput
Supports 100/200/400 Mbps connections
Fully IEEE 1394 compliant
Connect up to 63 devices together (by daisy chaining)
USB 2.0
Provides four up/downstream ports
480 Mbps data throughput
100% Backward compatible with USB v1.1
USB & IF certified
Chain up to 127 devices together (by daisy chaining)
Plug-n-Play, hot swappable
Automatically switches to the highest speed supported by peripheral
Hot Pluggable - connect devices without restarting the computer
Easy to install - no jumpers, switches or terminators required
Warranty: 3-YEARFunction Diagram
Requirements
Mac
PowerMac G3 (Blue & White Tower) or later
Mac OS v8.6 or higher
* Mac OSX 10.1.5 or higher is required for USB 2.0 functionality
64MB of RAM
Available USB 2.0 and FireWire ports
PC
Pentium or K6 - class processor (266Mhz or higher)
Windows 98 Second Edition or later
64MB of RAM
Package Content
One GUH420 USB 2.0 (4-Ports)/ FireWire (3-Ports) Combo Universal Hub
One USB 2.0 6 feet A type to B type Cable
One FireWire 6 feet 6 pin to 6 pin Cable
One 100-240VAC, DC 5V 2.6A Switching Adapter
One Warranty Card
One Quick User Guide
Specifications
UPC: 881317003577
Function GUH420
Housing
Case Plastic
Power
Voltage 5.0V
Amps 2.6A
Power Consumption 5.0V - 2.6A
Ports 4 USB 2.0 3 FireWire
Operating Temperature 20 to 50 degrees (Celsius)
Storage Temperature 0 to 70 degrees (Celsius)
Operating System Support Windows®, 98SE, 2000, ME, XP, MAC OS 8.6 or greater
FireWire Specification IEEE 1394-1995, P1394a (rev 1.1) and OHCI Interface specification 1.0 compliant.
USB Specification USB 1.1 and 2.0 compliant
Transfer Rate 400 mbps - 480 mbps
Humidity 20-80% RH, (Non Condensing)
Cable Length 6 ft. (1.83 m.)
Power Connections DC adapter (included)
Power Adaptor Part # 100-240VAC Switching (JODEN)
Dimensions GUH420
Unit Dimensions
Width 3.42 in (8.7 cm)
Height 5.9 in (15 cm)
Depth 1.18 in (3 cm)
Unit Package Dimensions
Width 7.95 in (20.2 cm)
Height 10.75 in (27.3 cm)
Depth 3.74 in (9.5 cm)
Master Carton
Width 16.8 in (42.8 cm)
Height 12.0 in (30.5 cm)
Depth 18.3 in (46.4 cm)
Master Carton Qty. 12
Weight
Master Carton Wt. 20.78 Kg (9.43 Kg)
Unit Pack Wt. 1.18 lb (0.54 Kg)
Unit Wt. 0.32 lb (0.15 Kg)
2.數量 : 1
6.交易方式:面交,郵寄或宅配
讓給有需要的人~
產品規格如下:
Description
FireWire
USB 2.0
USB & IF certified
Requirements
Mac
64MB of RAM
PC
64MB of RAM
Package Content
One Warranty Card
Specifications
UPC: 881317003577
Function GUH420
Housing
Case Plastic
Power
Voltage 5.0V
Amps 2.6A
Dimensions GUH420
Unit Dimensions
Master Carton
Weight
