xp開機出現藍色問題
kobe_tedy
[SIZE="6"][FONT="新細明體"][/FONT][FONT="新細明體"][/FONT]COLOR="RoyalBlue"]電腦開機 進入Windows XP畫面 出現藍色當機畫面 自動幫我重開機 就恢復正常 沒次開機 會這樣問題
藍色畫面訊息
A problem has been detected and Windows has been shut down to prevent damage
to your computer.
The problem seems to be caused by the following file: ntoskrnl.exe
PAGE_FAULT_IN_NONPAGED_AREA
If this is the first time you've seen this stop error screen,
restart your computer. If this screen appears again, follow
these steps:
Check to make sure any new hardware or software is properly installed.
If this is a new installation, ask your hardware or software manufacturer
for any Windows updates you might need.
If problems continue, disable or remove any newly installed hardware
or software. Disable BIOS memory options such as caching or shadowing.
If you need to use safe mode to remove or disable components, restart
your computer, press F8 to select Advanced Startup Options, and then
select Safe Mode.
Technical Information:
*** STOP: 0x10000050 (0xebd5ff44, 0x00000000, 0x805c2a86, 0x00000002)
*** ntoskrnl.exe - Address 0x805c2a86 base at 0x804d8000 DateStamp 0x4a7833f1
請問記憶體問題嗎 怎麼解決問題
