XoftSpySE Anti-Spyware v7.0-SND
代碼:
Description:
Looking for the easiest way to fight spyware? XoftSpySE
Anti-Spyware 7.0 is the answer. This trusted anti-spyware program is well known for its speed and removal of spyware, adware, annoying pop-up generators, keyloggers, Trojans and other malware.
XoftSpySE Anti-Spyware 7.0 is easy to install and use. Its common sense interface puts the full features of this powerful software in your hands. You simply choose the scan you want and XoftSpySE Anti-Spyware 7.0 goes to work. It will scan deeply to find all kinds of malware, threatening to steal your identity and credit card information, bombard you with advertising and monitor your online activities. As well, it will help keep your PC running right by removing malicious code that can slow you down.
This sophisticated software is jam packed with features to protect you and your PC. An innovative Browser Helper Object Editor will remove all of those aggravating toolbars and other add-ons that just clutter up your browser. XoftSpySE Anti-Spyware 7.0 also features a Startup Editor that lets you manage which programs launch when you turn on your computer. As well, the advanced scheduling feature makes it easy for you to ensure your PC is protected.
Step 1: Install the program
Step 2: Backup the original executable
Step 3: Replace with the cracked executable
Step 4: Run the application.
*iMPORTANT: Set XoftSpySE.exe to read-only to avoid self update!
代碼:
Download Link: (Rapidshare)
http://rapidshare-mm.blogspot.com/2009/12/part1_9499.html
No Pass
