[新竹售] Trek 156A靜電消散分析儀 (離子風扇或離子消散裝置功能檢測)
  • 主題發起人 主題發起人 kuan0726
kuan0726
1.品名 : Trek 156A靜電消散分析儀
2.數量 : 一台
3.品相及保固 :8.5成新,功能運作正常,原廠已過保,個人保7天,可面交測試,原價175000元,因目前用不到擺在倉庫,故以不到半價出售,此機有蓄電功能不需插電亦可使用,蓄電池可續電但不復新機的續航能力,充飽電約可用30分鐘,如有插電使用則隨時都可使用,配件為充電器及測試板各一個如附圖所示
4.售價 :83000(面交) 83200(宅配)誠可小議或可用等價位物品更換,欲更換物品請詳細說明及附圖以供參考
5.地點 :竹北(面交) 全省(宅配)
6.交易方式:可宅配,可面交
7.原廠介紹:
Trek Model 156A離子平衡測量儀,主要用於監控離子產生器及離子風扇的工作效率。156A具有兩種檢測模式(衰減時間Decay Time和平衡度Balance),功能簡單輕巧,2個開關即可搞定所有量測項目,檢測板為分離式,對於放置在狹小空間的離子消散裝置亦可輕鬆量測,非一般舊式笨重儀器所能比擬,
原文說明:
Model 156A & Model 156A/1 CHARGED-PLATE MONITOR
The Trek Model 156A Charged-Plate Monitor System is designed to provide quantitative measurements of the effectiveness of air ionization systems, as to audit ionizer performance.
The Model 156A employs a revolutionary charged-plate monitor design that utilizes an ultrahigh-impedance, high-voltage follower to monitor the ion collecting plate voltage. This technique provides very high accuracy and virtually infinite impedance loading of the plate, while allowing the ion collecting plate to be charged and monitored through the same small-diameter connection. This technique also makes the measurement capacitance independent of the physical size and shape of the ion plate. Therefore, the size and shape of an ion collecting plate, as well as the measurement capacitance, may be customer specified to match a particular ESD-sensitive device within a manufacturing process, or it may be made to conform to the EOS/ESD Association Standard STM3.1-2000.
The Model 156A features two modes of operation, a decay mode with easy-to-program start and stop voltages, and a float mode. For decay mode operation, the ion collecting plate is precharged to a level above the programmed START voltage. The time required to discharge the ion collecting plate from the programmed START voltage to the programmed STOP voltage due to incident ion flow to the ion collecting plate from the measured ion field is indicated by the Model 156A. In the float mode of operation, the plate is initially discharged to zero and then allowed to float to the voltage level dictated by incident ion flow to the ion collecting plate from the measured ion field.
The simplicity of the design of the Model 156A makes it very reliable and completely portable. The Model 156A is powered by an internal rechargeable battery that offers 8 hours of operation from a full charge.
The Trek Model 156A/1 has a serial interface port to connect with a computer. Computer Software allows the operator to program test sequences, save, or retrieve test results. Any series of tests can be duplicated, analyzed, programmed or retrieved using PC based software.
PERFORMANCE
• Monitored Voltage Range
0 to ±1100 V DC or peak AC.
• Small Signal Bandwidth (-3 dB)
DC to 1 kHz (measured at 20 V p-p).
• Large Signal Bandwidth
DC to 10 Hz (measured at 2000 V p-p).
• Zero Stability (referred to plate voltage)
Drift with Time (no incident ion flow)
Less than 6 V/minute.
• Drift with Temperature
Less than 10 mV/°C, noncumulative.
• Decay Mode Thresholds
o Start Voltage
156A unit,156A/1 unit and software programmable from 1 to ±1000 V in 1 V increments.
o Start Accuracy
156A unit,156A/1 unit and software within ±1 V of programmed start voltage.
o Stop Voltage
156A unit,156A/1 unit and software software programmable from 0 to ±999 V in 1 V increments.
o Stop Accuracy
156A unit,156A/1 unit and software within ±1 V of programmed stop voltage.
• Plate Self-Discharge (unpolarized)
Less than 12 V/minute.
156A主機
充電器及測試電極板
自推一下,降售68000(面交) 68500(宅配),誠可小議,或可用等價位物品更換
