3870X2跳水中!忍不住買了一張!拿到手盒子很大外加疑惑一推!
配件滿齊的!
與3870相比,3870x2比較氣派!
側面來一張!看得出來外殼會造成一推廢熱,晚點再把它脫光!
上機測試囉!E6420不夠力,過幾天再換個有力的處理處理.
3D06分數15995;smash;
接著試著讓3870X2與3870交火看看,出包中;oplc;
兩片互換位置還是出包!看一些測試報告應該是可以交火的,怎會這樣?
GPU-Z與CCC的顯示結果,無法做CF:PPP:
後續動作,換過8.9/8.10都無法成功顯示CF WORK.
會想買3870X2也是因為看到3870可以與3870X2交火,才敗下去的.
說明如下:
主要特性
1、支持三路、四路CrossFireX
可使用Radeon HD 3870/3850/3870 X2顯卡任意搭配,組成2/3/4顆GPU並聯系統,今後的催化劑驅動還會繼續改善多路相容性、提高性能。
2、支持Hybrid Grapics(俗稱混合交火)
針對AMD 780G整合主板和ATI Radeon HD 3400系列顯卡(支援PowerPlay技術)設計,獨立顯卡和集成顯卡並行可大幅提高系統性能,也可關閉獨立顯卡運行在節能模式。
The CrossfireX driver will allow you to make a quad Crossfire setup from one 3870X2, one 3870 and one 3850, but we are not sure how it will compare in speed to four 3870s in CrossfireX.
I am sure that enthusiasts will like it as this now means that despite the fact that you have a 3870 or a 3850, you can add unequal cards, including the 3870 X2 and gain a lot of performance.
We can now definitely confirm that CrossfireX means a flexible way to use more than one card. However, we are sure that you won’t be able to add more than four chips to work together and it remains to be seen if you'll be able to mix these high-end cards with 36x0 series or slower, which we sincerely doubt.
希望大家能提供一些方向,我會再做測試.;ng;
配件滿齊的!
與3870相比,3870x2比較氣派!
3D06分數15995;smash;
說明如下:
主要特性
1、支持三路、四路CrossFireX
