Wise PC Engineer 6.39 Build 215
  • 主題發起人 主題發起人 mikotoyou
mikotoyou
Wise PC Engineer 6.39 Build 215 | 8.05 MB
Wise PC Engineer is a bundle of most important system utilities for performing different tasks on your PC! It not only can help you clean Windows Registry, free up disk space, defragment registry and disk, erase privacy data and recover lost file, it also can hidden important file or folder for you, lockup your personal applications. Of course, you can call it as super registry cleaner software, or super disk cleaner. After using, you'll find it really a ALL-IN-ONE PC tools for improving PC Performance. If your computer are running slower and slower, please don't hesitate to use Wise PC Engineer, it will help you keep your pc running at optimum performance! Wise PC Engineer uses a advanced Scan algorithm to quickly identify missing and invalid references in your Windows registry and junk files. You could be albe to choose to selectively clean each item or automatically fix them all. Also supports system optimization, including Erasing Internet Tracing, Cleaning Windows Registry, Cleaning Disk and Tweak System Performance.
With Wise PC Engineer you can safely clean, repair and optimize the Windows registry and free up disk space with a few simple mouse clicks! It also supports 1-Click tune up for novice.
Wise PC Engineer supports full Registry Backup and Registry Restore, Creating System Restore Point, Creating undo data for each clean-up operation, Marking the scanned results as safe or unsafe, all of that make it absolutely secure.
What can Wise PC Engineer do:
• Registry Backup
• Registry Cleaner
• Registry Defragment
• Startup Program Manager
• Disk Cleaner
• Disk Defragment
• File Recovery
• File/Folder/Drive Scrub
• Memory Optimizer
• Windows Auto Shutdown
• File/Folder Hider
• Application Encrypt and Unencrypt
• 1-Click Tune-up
Designed for Windows 7 (32/64 bits), Vista (32/64 bits), XP, 2008 server, 2003 and 2000.
Homepage -http://www.wisecleaner.com/wisepcengineer.html
Download FileSonic
代碼:
http://www.filesonic.com/file/EBlCzvl/
