萬用的SLI Patch?
熱鬥小狐
A while back Asrock published a SLI enabling patch for their ULi chipset based motherboards that have two PCI-Express slots. Various rumors suggested that the patch would also function under other chipsets as well, and allow users with other chipsets to use SLI on their non-SLI motherboards. Unfortunately the original version of the patch installs only on ULi 1695/7 chipsets - you couldn’t use it if you didn’t have a motherboard with that particular chipset.
We’ve managed to rip the installer and to create a modified version of the SLI patch that allows you to use it with EVERY motherboard. We couldn’t do in-depth testing on other chipsets, but if the rumors are true then it should definitely work. Feel free to use it at your own risk, and please post the results in our forums. Remember, this is a modified version and is not supported by Asrock, ULi or Nvidia.
Installation: Just run SLI Patch.exe and follow the instructions. After the installation, restart your computer TWICE.
Removal: Control Panel > Add and Remove programs > SLI Patch
Supported OSes: Microsoft Windows XP/2000
果然有高手出來了,大家來試一下吧,不過記緊做好備份
http://file2.mydrivers.com/board/nvidia_slity3306.exe
收啦!!
肛溫
謝謝大大了!!
先下載下來再說
收了................. ;em28;
感謝分享......... ;em25;
好像沒提到INTEL的955跟975...
著名的NGO小組通過破解ULI PowerExpress Engine Enabling驅動的安裝程序成功的修改出一個萬用的SLI補丁,也就是說只要主板有多PEG通道,即可使用SLI模式,無須Nvidia的認可,也不用管它是哪一家的晶片組,已知有下列晶片組符合此條件:Intel 975X、Intel 945P、VIA K8T900、ATI RD580、ATI RD480、ULi M1697、NVIDIA nForce4 Ultra、NVIDIA nForce4 4X。
特別注意:NGO小組在其網站上聲明此款修改版補丁還沒有經過比較深入的測試,不能保證一定能成功,使用者自擔風險
剛剛用技嘉的G1組SLI~不能開= =.....
