virtual box不能裝win7 64bit
  • 主題發起人 主題發起人 axz1250
axz1250
啟動後跑出下面這張畫面,看不懂訊息
google也找不到處理辦法
我的系統是win7 64bit現在要安裝虛擬的win7 64bit無法安裝
我用虛擬機最多是裝XP 32位元的
所以不知道我的觀念正不正確
如果你的virtual box是32位元的
那就不能裝64位元的作業系統吧
畢竟整個基礎是32位元的
64-bit guests
VirtualBox supports 64-bit guest operating systems, even on 32-bit host operating systems, provided that the following conditions are met:
You need a 64-bit processor with hardware virtualization support.
You must enable hardware virtualization for the particular VM for which you want 64-bit support; software virtualization is not supported for 64-bit VMs.
If you want to use 64-bit guest support on a 32-bit host operating system, you must also select a 64-bit operating system for the particular VM. Since supporting 64 bits on 32-bit hosts incurs additional overhead, VirtualBox only enables this support upon explicit request.
On 64-bit hosts (which typically come with hardware virtualization support), 64-bit guest operating systems are always supported regardless of settings, so you can simply install a 64-bit operating system in the guest.
http://www.start64.com/index.php?option=com_content&task=view&id=1340&Itemid=73
按描述需要64位元處理器並具備硬體虛擬化技術
軟體虛擬化不支援64位元虛擬機器
只要支援硬體虛擬化技術就算32位元作業系統也能模擬64位元系統環境(需選擇64位元版本)
像Q8200之類處理器缺乏虛擬化技術支援因此無法使用
終於解決了..
到BIOS裡面打開虛擬化技術就行
不過裝到一半失敗又跑去BIOS開啟VT功能
現在已經OK
BIOS沒有開啟VT功能
開啟過後就可以再虛擬機安裝了
