uTorrent V2.0.0 Build 16394 Beta_非常小巧的 BT 客戶端
  • 主題發起人 主題發起人 le2712
le2712
【軟體名稱】:uTorrent V2.0.0 Build 16394 Beta
【軟體語言】:多語
【軟體分類】:檔案傳輸
【軟體性質】:免費
【檔案大小】:414 KB
【放置空間】:badongo \ depositfiles
【解壓密碼】:no
【軟體介紹】:
很小巧的BT客戶端程序,擁有常見的功能,但是不支援UDP的連接協議。內網下載方面也有不錯的表現,外網就更不用提了。支援多任務同時下載,支援設置文件下載優先級,可以根據計劃任務調整占用的帶寬,全局/單個任務的速度限制,快速斷點續傳機制,支援UPnP,支流行的BT擴展協議,支援使用者來源交換,支援DHT最小內存占用僅6MB!
Changes in Version 2.0 Beta (build 16394), 2009-09-04:
- Fix: bugs where have messages would not be remebered for magnet link downloads
- Fix: Buffer overrun vulnerability
- Change: Conservative network locking in installer
- Fix: rare crash in low level network read and write
- Fix: fixed crash in udp tracker connection with unresponsive DNS
- Fix: improved out-of-memory error handling in disk thread
- Fix: Installer crash after download
- Fix: Crash when peers disconnect from a magnet-link torrent right as we received the matadata
- Feature: Stop setup guide tests without exiting dialog
- Fix: Fixes bug where magnet links wouldn't work if PEX was disabled
- Feature: added ability to re-run setup tests
- Fix: Fix crash when using magnet links and a peer is failing at a particular point
- Fix: Fixed negative allocation in RequestChunks() for web seeds
- Change: Updated bandwidth presets in Setup guide
- Fix: Fix startup race condition between network and disk I/O thread
- Change: Optimization added to speed up torrent creation
Homepage - http://utorrent.com
確保下載的軟體能正常使用,請使用
WinRAR 3.90 Final 版本解壓
