Tera Copy Pro v2.12
  • 主題發起人 主題發起人 viet80
viet80
Tera Copy Pro v2.12
Info:
TeraCopy is a great utility designed to copy/move files faster and more secure. TeraCopy can resume broken file transfers. TeraCopy skips bad files during copy and even shows the skipped files at the end of files transfer. Calculates files CRC checksum on the fly to speed up source and target files comparison. Seamless integration with Windows Explorer allows you to keep working with files as usual.
TeraCopy is a compact program designed to copy and move files at the maximum possible speed, providing the user a lot of features:
* Copy files faster. TeraCopy uses dynamically adjusted buffers to reduce seek times. Asynchronous copy speeds up file transfer between two physical hard drives.
* Pause and resume file transfers. Pause copy process at any time to free up system resources and continue with a single click.
* Error recovery. In case of copy error, TeraCopy will try several times and in the worse case just skips the file, not terminating the entire transfer.
* Interactive file list. TeraCopy shows failed file transfers and lets you fix the problem and recopy only problem files.
* Shell integration. TeraCopy can completely replace Explorer copy and move functions, allowing you work with files as usual.
* Copy/move to favorite folders. (Pro)
* Select files with the same extension/same folder. (Pro)
* Remove selected files from the copy queue. (Pro)
* Full Unicode support.
* Windows 7 x64 support.
What's New in TeraCopy v2.12
* Fixed: Copy not started automatically.
* Added: Multi-monitor support.
* Added: Run additional app on finish (eject disk, etc).
Download Link:
代碼:
Hotfile
http://rapidshare-8.blogspot.com/2010/03/part1.html
No Pass
Rapidshare
http://rapidshare-8.blogspot.com/2010/03/part1_23.html
No Pass
我之前有用過家用版的!!
不知道pro有怎樣的不一樣??
