Talisman Desktop 是一個讓你可以任意調整與制定自己想要的桌面的工具
你可以自己customize出自己想要的menu樣式, 加入其他程式的捷徑, 有很多很棒的功能
抱歉我沒辦法一一翻譯了 大家可以到官方網站稍微看一下
它有screenshots
安裝方式:用序號產生器註冊
檔案大小: 7.44M
下載連結: http://rapidshare.com/files/155436431/Talisman_Dessktop__3.02B.rar.html
官方網站 http://www.lighttek.com/talisman.htm
Features:
Creating multilevel user defined fullscreen desktops
Creating Desktop Panels on Windows Desktop
Opportunity to replace the default shell of Windows 9x/NT/2000/ME/XP/Vista explorer.exe with talisman.exe
Use of any number of pictures, buttons, objects of any type or dimension, instead of standard icons.
Place, free-moving and imposing of objects in the Talisman workspace.
All objects can run external programs or internal shell commands or http:// URLs by one click of the mouse.
The number of forms (screens) in one theme is not limited. Any screen object can be set to switch from one form to another.
You can create a set of independent themes, and store them on any disk in the local computer or on a local area network.
You can easily switch between different themes through your own objects or through the Talisman menu.
The Built-in Object Editor allows the creation, modification and removal of any element in a theme.
Large number of basic elements (forms, pictures, shapes, buttons of different types, text blocks, inputboxes, calendars, clocks, timers, HTML-documents, Flash and VRML documents.
Customizable taskbar, system tray, clock.
Sound support for all events.
Startmenu, foldermenu, taskmenu, controlmenu, custom menu and other menu objects.
Script language.
Messages engine for communication with other programs.
Plugins.
HotKeys.
Keyboard control.
Protection and limited access functions.
它有screenshots
安裝方式:用序號產生器註冊
檔案大小: 7.44M
Features:
Script language.
Plugins.
HotKeys.
Keyboard control.
